chek cho nó 1 file PM chuẩn vào ùi phang lại là đc :|Được post bởi Field: 13, Field: 21, Record: 0, Len: 8->Error code: 4
Field: 21, Record: 1, Len: 8->Error code: 4
Field: 21, Record: 2, Len: 8->Error code: 4
Field: 21, Record: 3, Len: 2->Error code: 4
Field: 21, Record: 4, Len: 928->Error code: 4
Field: 21, Record: 5, Len: 1->Error code: 4
Field: 21, Record: 6, Len: 8->Error code: 4
Field: 21, Record: 7, Len: 8->Error code: 4
Field: 104, Record: 0, Len: 3->Error code: 4
Field: 120, Record: 0, Len: 78->Error code: 5
Field: 139, Record: 1, Len: 8->Error code: 5
Field: 139, Record: 2, Len: 44->Error code: 5
Field: 139, Record: 3, Len: 10->Error code: 5
Field: 139, Record: 4, Len: 8->Error code: 5
Field: 139, Record: 5, Len: 8->Error code: 5
Field: 139, Record: 6, Len: 8->Error code: 5
Field: 139, Record: 9, Len: 5->Error code: 5
Field: 144, Record: 0, Len: 4->Error code: 5
Field: 144, Record: 1, Len: 32->Error code: 5
Field: 144, Record: 2, Len: 4->Error code: 5
Field: 151, Record: 3, Len: 302->Error code: 5
Field: 151, Record: 4, Len: 302->Error code: 5
Field: 151, Record: 5, Len: 302->Error code: 5
Field: 151, Record: 6, Len: 302->Error code: 5
Field: 151, Record: 7, Len: 302->Error code: 5
Field: 151, Record: 8, Len: 302->Error code: 5
Field: 151, Record: 9, Len: 302->Error code: 5
Field: 151, Record: 10, Len: 302->Error code: 5
Field: 151, Record: 11, Len: 302->Error code: 5
Field: 151, Record: 12, Len: 302->Error code: 5
Field: 156, Record: 0, Len: 4->Error code: 5
Field: 156, Record: 1, Len: 32->Error code: 5
Field: 156, Record: 2, Len: 4->Error code: 5
Field: 187, Record: 0, Len: 3->Error code: 4
Done!
sau đó tôi info ra nó thế này:MCU ID: 0x2201
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.40
12-01-07
RH-93
(c) NMP
HW version: 0502
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: WIN:MYKS:01
ST7506
PPM version: V 6.40
12-01-07
RH-93
(c) NMP
MD
ADSP SW version: V 6.40\n12-01-07\nRH-93\n(c) NMP\nmd
Production serial number: KHN173991
Product code: 0533130
Module code: 0203167
Basic production code: 0532665
Flash code:
Order number: 1234567
Product specific data:
Long production SN:
ATO: c?006032003 13:09:26??????CL??0???????????????????
Default SN type: c?006032003 13:09:26??????CL??0???????????????????IMEI plain: 356209000501558
IMEI spare to net: 3A 65 02 09 00 05 51 05
IMEI SV to net: 33 65 02 09 00 05 51 35 F5
Master Code: 5526160435
Phone type: RH-93, Software version: 6.40, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0533130
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Scanning for ini files...
INI file 0533130.ini is missing. Continue searching for second ini type...
Checking path: \Products\RH-93\
No ini files found...
CNT Flash file: rh930_nai6.40?
Done!
[COLOR="Red"
