Kết quả 1 tới 10 của 10
    Thành viên tích cực ngtammy's Avatar
    Sep 2008
    Mặc định 1600 chạy tiếng việt không được
    mấy anh xem dùm em chay như vậy mà không có tiếng việt
    JAF version 1.98.61
    Detected PKEY: 9001E24F
    Card life counter: 95.84%
    Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 6.93
    10-08-07
    RH-64
    (c) NMP
    HW version: 0502
    PCI version:
    UEM version: 1314
    UPP version: 8705
    RFIC version: 0500
    DSP version: P05w06.v34
    LCD version: SDI:NAXv87
    LDS184
    PPM version: V 6.93
    10-08-07
    RH-64
    (c) NMP
    QC
    ADSP SW version: no NAI version
    Production serial number: MOG343535
    Product code: 0525397
    Module code: 0202591
    Basic production code: 0520754
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 359378008760552
    IMEI spare to net: 3A 95 73 08 80 67 50 05
    IMEI SV to net: 33 95 73 08 80 67 50 45 F3
    Master Code: 2771667740
    Phone type: RH-64, Software version: 6.93, Language Pack: QC
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini
    Setting local mode...
    Reading product code...
    Product Code: 0525397
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\
    Scanning for ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_04.030
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_04.03md
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai4.03md
    Languages in ppm: English,Filipino,Vietnamase
    Done!
    Phone Type: RH-64
    Reading...
    Phone Type: RH-64
    MCU Flash file: D:\chuong trinh my\Products\rh-64\rh64_06.930
    Phone Type: RH-64
    PPM Flash file: D:\chuong trinh my\Products\rh-64\rh64_06.93qc
    Languages in ppm: English,Chinese S,Vietnamese
    Phone Type: RH-64
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: D:\chuong trinh my\Products\rh-64\rh64_06.930
    Booting phone...
    MCU ID: 0x2201
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x7E2A0100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: c6
    Loader is ready...
    MSID: 84855E6A54E8920D3F720F9DB6
    MSID decoded: 3E4EBAE9000AFE13A9000000
    FAID: 1F84E2CC6E42A732B57BA182
    Operation took 0 minutes 8 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 27 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 12 seconds...
    Restarting MCU...
    PPM: D:\chuong trinh my\Products\rh-64\rh64_06.93qc
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8435A15C60C533D31453C32413
    MSID decoded: 3E4EBAE9000AFE13AA000000
    FAID: 47F2605BBA340B888A116588
    Operation took 0 minutes 7 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011D0000 - 011DFFFF...
    Erasing area: 011E0000 - 0137FFFF...
    Writing...
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 23 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    IMEI: 359378008760552
    Resetting PPC...
    Done!
    Sep 2008
    có ai giúp mình không vậy cần gấp
    V.I.P tuanmb's Avatar
    Feb 2008
    Boot is ready...
    xóa full flash, lấy vs cao hơn nạp vào nhe bạn
    Thành viên tích cực ngocquy_mobile's Avatar
    Mar 2006
    Quất Lâm beach
    File của bạn như vậy là đã có tiếng việt rồi. bạn thử khởi động lại nguồn thử xem thế nào ?
    ĐỪNG HỎI VÌ SAO ANH YÊU EM - 0949.106.106-Y/h: comeback_tome2004vn
    V.I.P HoangViet902's Avatar
    Sep 2008
    Núi Bà Đen
    chạy file vậy làm sao có tv được chứ , chạy lại file ppm_md mới có tv , qc chạy tới già cũng ko có
    V.I.P DinhKha™'s Avatar
    Jul 2008
    Kiên Giang
    chọn file ppm có đuôi là md chạy 1 phát là tiếng việt rầm rầm luôn đó bạn.
    BUZZ cho mình đi,mình send cho 1 file giải nén sẳn về flash.
    Sep 2008
    Trích Được post bởi tuanmb Xem bài viết
    Boot is ready...
    em thử chạy ver cao hơn rồi nhưng cũng không được
    Sep 2008
    Núi Bà Đen
    Trích Được post bởi ngocquy_mobile Xem bài viết
    Phone Type: RH-64
    chạy file như vậy ko có tv đâu bạn ah
    rh64_06.93MD mới có tv
    Sep 2008
    Trích Được post bởi HoangViet902 Xem bài viết
    cám ơn nhiều nha lam như vậy ok liền
    Thành viên kỳ cựu CHHONGQUAN's Avatar
    Jul 2008
    chạy md luôn luôn có tv
  1. Xin File Tiếng Việt 1600 Ver 5.53
    By thangvn in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 25-02-2012, 14:39
  2. cần gấp file 1600 v6.90 tiếng việt
    By sutuden in forum DCT4 - WD2
    Trả lời: 20
    Bài viết cuối: 07-07-2011, 17:20
  3. cần file tiếng việt 1600
    By dangkhanh_mobile in forum DCT4 - WD2
    Bài viết cuối: 24-06-2011, 11:55
  4. 1600 file tiếng thái
    By loiphone in forum DCT4 - WD2
    Bài viết cuối: 19-10-2009, 18:07
  5. Trả lời: 8
    Bài viết cuối: 25-02-2008, 12:41
