tai. sao cái log này của e .e phải INF 3 lần thì mới dc.chay xong thì nó báo thế này
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
Master Code: 3013414237
Failed! Aborting! MCUVER
Reading...
Failed reading simlock data...
Phone type: RH-51, Software version: 7.0642.0, Language Pack: not available
User code: 12345
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
Setting local mode...
Failed! Aborting!
Done!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Checking path: \Products\RH-51\
No ini files found...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\350774602175826_imei_back up_2045279.rpl
Done!
Backup imei OK!
Flashing Done!
After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...MCUVER
Phone Type:
MCU Flash file: D:\nokia\7610\RH51_52_67_68PE706420.C1
Phone Type:
PPM Flash file: D:\nokia\7610\RH51PE706420.06
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\350774602175826_imei_back up_2055279.rpl
Done!
Backup imei OK!
MCU: D:\nokia\7610\RH51_52_67_68PE706420.C1
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Boot size is 0x10D8
Boot is ready...
Flash ID is 0x22F800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: ac
Loader is ready...
MSID: 844E3003B13C5EB4DC4C7DE908
MSID decoded: 3E4EBAF70043EE2CA9000000
FAID: 3DABCBA254EF400D094BD2BF
Operation took 0 minutes 16 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 0287FFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 3 minutes 35 seconds...
Writing...
Perm. Data Restore OK
Operation took 3 minutes 7 seconds...
Restarting MCU...
PPM: D:\nokia\7610\RH51PE706420.06
Booting phone...
MCU ID: 0x1081
Boot size is 0x10D8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 02A00000 - 02CAFFFF...
Operation took 0 minutes 23 seconds...
Writing...
Operation took 0 minutes 21 seconds...
Restarting MCU...
Flashing Done!
Operation took 8 minutes 4 seconds...
Reading...
