em đang bị một cây 6230 hang xách tay.
hiên tương là không có sóng. tìm được đủ cả 3 mạng nhưng không truy cập dc, nhân thể em post cái log lên anh em chỉ giúp với
Getting MCU ID
Phone didn't answer with TX line low after UEM reset!
Causes:
1. put a 27-33 pico capacitor in connector b/w mbus-gnd.
2. UEM damaged -> replace uem.
MCU ID: 0xDDDD
Failed! Aborting!
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.15
17-03-04
RH-12
GSM P1.1
(c) NMP.
HW version: 0600
PCI version:
UEM version: 288
UPP version: 4178
RFIC version: p
10ff11ff0203
DSP version: p
A0412_MATRIX
LCD version: SHARP
PPM version: V 03.15
17-03-04
RH12_28_-
GSM
D
BT MCM version: 0380
ADSP SW version: ADSP_MR2_v9
Production serial number: KHH541049
Product code: 0513085
Module code: 0201879
Basic production code: 0509076
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352953000714984
IMEI spare to net: 3A 25 59 03 00 17 94 08
IMEI SV to net: 33 25 59 03 00 17 94 08 F2
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 6657310005
Phone type: RH-12, Software version: 03.15 , Language Pack: D
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-12.ini
Setting local mode...
Reading product code...
Product Code: 0513085
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-12\
Checking path: \Products\RH-12\
No ini files found...
Done!
thanks các bác trước!
