Kết quả 1 tới 10 của 12
    V.I.P Thanh_6868's Avatar
    Oct 2008
    Mặc định 3510 tự tắt nguồn
    mình mới nhận cây 3510 , dùng khoảng 1phuts máy tự động tắt nguồn, đã nạp lại flash ,write pm,unlock,
    Thành viên mới Lê Minh's Avatar
    Dec 2008
    Trích Được post bởi nguyendangthanh Xem bài viết
    imei ??????????
    NHẮC NHỞ LẦN ĐẦU NHÉ BẠN!! TRẢ LỜI NGHIÊM TÚC NHÉ! NẾU KHÔNG SẼ SỬ THEO NỘI QUI
    Last edited by TAMTRUONGTELECOM; 12-01-2009 at 19:25. Lý do: BÀI POST KHÔNG RÕ RÀNG
    $ không phải là vấn đề, mà ... vấn đề là có bao nhiu $
    quocchuong566
    Guest quocchuong566's Avatar
    xóa flash chạy lại rồi up logo lên đi bạn
    Oct 2008
    anh em kiểm tra xem cho mình cái log nhé
    Booting phone...
    MCU ID: 0x0120
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 7E220100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Flash ID is 0x7E220100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: e8
    Loader is ready...
    MSID: 84081C47EF3BF132B669A98858
    MSID decoded: F6D3BAE900CA15C6A8000000
    FAID: 1FE6F6DFB3D460EA8D8EF0B4
    Operation took 0 minutes 16 seconds...
    Erasing...
    Found 2 interval(s) to erase
    Erasing area: 01010000 - 017EFFFF...
    Operation took 2 minutes 17 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 41 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\NHM-8\nhm8nxp5.02g
    Booting phone...
    MCU ID: 0x0120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 15 seconds...
    Erasing PPM...
    Found 1 interval(s) to erase
    Erasing area: 015A0000 - 016CFFFF...
    Operation took 0 minutes 20 seconds...
    Writing...
    Operation took 0 minutes 7 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 4 minutes 2 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: NHM-8, Software version: 5.02
    IMEI: 350843800254707
    Product Code: 0507952
    Resetting PPC...
    Done!
    Oct 2008
    tháo sim ra bật nguồn lên,cứ để cũng tự tắt nguồn
    V.I.P QuốcBình's Avatar
    Aug 2007
    GIA HUY MOBILE VŨNG TÀU
    con này bị lỗi ic nguồn rồi bạn.nguồn này có đỗ keo đụt cẩn thận nhe bạn.chúc vui
    GiaHuy Mobile-Song vĩnh.Tân phước.Tân thành.BRVT-0643.922.999-09888.7.1112
    VCB.0081000752371-Agibank.6004205000674-Mua bán,sữa chữa iphone-Nokia 8800
    Oct 2008
    Trích Được post bởi quocbinh_baria Xem bài viết
    ok,mình đào thôi có gì thong báo nha, thank
    Thành viên tích cực Q.Cuongmobile's Avatar
    Dec 2007
    làm nguồn không hết thì nhổ luôn upp đi bạn chúc bạn thành công nha
    Oct 2008
    trời .máy khách đem vô vẫn có nguồn bình thường ko bít quả này còn lên nguồn nữa ko?
    Thành viên tích cực NhatDang_DaiSu's Avatar
    Feb 2008
    Sao thế vẫn có nguồn bình thường thì giờ chưa làm báo đi đã rồi làm. Tội gì mang vạ vào thân chẳng biết đuợc bao nhiêu lúa mà vất vả mang tiếng nữa chứ
    Website: http://gsm-server.mobi Service unlock code online
  1. 3510 mất nguồn
    By vantuan0973286172 in forum DCT3-DCTL
    Bài viết cuối: 27-12-2011, 11:10
  2. Trả lời: 0
    Bài viết cuối: 04-04-2010, 14:28
  3. m 3510
    By vungtaumobifone in forum Agere System
    Bài viết cuối: 23-11-2009, 11:36
  4. 3510 i mất nguồn cần giúp
    By thanhanh in forum DCT3-DCTL
    Bài viết cuối: 09-08-2009, 19:42
  5. cho em xin phân mềm 3510
    By Minh Dang in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 15-07-2009, 10:44
