anh em sem giúp em cái log này với máy bị rơi nước mất nguồn em bỏ vô jaf check nó báo thế này
MCU ID: 0x3040
FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_v
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
Booting phone...
Phone didn't answer with TX line high after UEM reset!
Causes:
1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
2.UEM damaged -> replace UEM.
MCU ID: 0xCCCC
This MCU ID is not supported in chosen flash file...
Error booting phone...
Failed! Aborting!
Booting phone...
MCU ID: 0x3040
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x01000000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: b2
Loader is ready...
MSID: 84F3E16133471216DECFEA2736
MSID decoded: 4F16BAE900C8BC76A8000000
FAID: 27C096FE29BD83785DA13204
Operation took 0 minutes 11 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 018DFFFF...
Erasing area: 01EE0000 - 01FDFFFF...
Writing...
Error cmd: 14!
Addr: 01000000
anh em xem giup em xem nó bị gì . cảm ơn anh em . thanks all
