Kết quả 1 tới 10 của 10
    Thành viên chính thức longvip's Avatar
    May 2007
    Mặc định 7610 khởi dộng lên tắt
    anh em nào dã làm ban này 7610 khởi dộng lên rồi tự tắt rồi tự khỡi dộng lại ,khi infô thì nó ra như thế này
    MCU ID: 0x1081
    FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    Master Code: 7652153651
    Failed! Aborting! MCUVER
    Reading...
    MCU SW version: V 7.0642.0
    18-10-06
    RH-51
    (c)NMP
    HW version: 7033
    PCI version:
    UEM version: 144
    UPP version: 4225
    Production serial number: PEN755169
    Product code: 0516453
    Module code: 0202215
    Basic production code: 0544172
    Flash code:
    Order number:
    Long production SN:
    ATO: p?????????????????????????????????????????????????
    Default SN type: p?????????????????????????????????????????????????
    IMEI plain: 354813017875392
    IMEI spare to net: 3A 45 18 03 71 78 35 09
    IMEI SV to net: 33 45 18 03 71 78 35 39 F3
    PDC: 4E 54 54 4A 50 12 34 56
    Phone type: RH-51, Software version: 7.0642.0, Language Pack: 01
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
    Setting local mode...
    Reading product code...
    Product Code: 0516453
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
    Scanning for ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.33
    Languages in ppm: English,Bahasa Mal.,Bahasa Ind. (Apac-3)Done! anh em coi cái ATO: p????????????????????????????????????????????????? và Default SN type: p?????????????????????????????????????????????????
    Thành viên kỳ cựu setot_thoi's Avatar
    Aug 2007
    Sóc Trăng
    nạp lại pm cho nó cái nha bạn .tìm fie full nha
    May 2007
    là chạy file pm sóng dó hã bạn ,có yahoo không send qua yahoo.chứ mình không có file
    Aug 2007
    Sóc Trăng
    kô phãi pm sóng đó ý nói là phần mềm đó bạn ơi . tìm mà nạp vào
    Thành viên chính thức truongsongsm's Avatar
    flat một cái coi sao đả
    SỬA CHỮA ĐTDD TRƯỜNG SƠN
    ĐC 414 QL20 ,LIÊN NGHỈA ,ĐỨC TRỌNG ,LÂM ĐỒNG ĐT:0974796579
    May 2007
    Mạng của tui yếu lắm bạn send cho tui di cảm ơn trước nha
    May 2007
    flash rồi vẩn vậy vẩn có chử ATO: p????????????????????????????????????????????????? Default SN type: p?????????????????????????????????????????????????
    Thành viên chính thức dinhtumobile's Avatar
    Oct 2008
    xoá full flash đi, rồi nạp lại phần mềm coi sao
    Thành viên tích cực vantuan_huemobile's Avatar
    Jun 2008
    vùng cao nam đông _huế
    ko hết thì bỏ con kiến 5 chân sau chân pin và sau cùng la uem thôi bạn ah.thân
    Thành viên kỳ cựu HÀ GIANG GSM's Avatar
    Apr 2009
    HÀ GIANG GSM
    oh ban chỉ càn chay lai cho chuân là ok liền thui mà
  1. 7610 trung quốc kep nguồn lên cho bin vào không lên
    By ngocthanh1202 in forum Sửa chữa phần cứng
    Bài viết cuối: 31-07-2013, 10:58
