Kết quả 11 tới 13 của 13
    V.I.P ThienKim GSM™'s Avatar
    Feb 2009
    Thành phố Dệt
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    <<<<< lỗi ở chỗ này kiểm tra lại BSI hoặc thay ic nguồn. UPP và FLASH đã nhận đủ
    Thành viên tích cực ngocminhhungyen's Avatar
    Feb 2009
    jhhj
    MCU SW version: V 6.93
    10-08-07
    RH-93
    (c) NMP
    HW version:
    PCI version:
    UEM version: 1328
    UPP version: 8705
    RFIC version: 0500
    DSP version: P05w06.v34
    LCD version: WIN:MYKS:01
    ST7506
    PPM version: V 6.93
    10-08-07
    RH-93
    (c) NMP
    IC
    ADSP SW version: V 6.93\n10-08-07\nRH-93\n(c) NMP\nic
    Production serial number:
    Product code:
    Module code:
    Basic production code:
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 358062012212351
    IMEI spare to net: 3A 85 60 02 21 12 32 05
    IMEI SV to net: 33 85 60 02 21 12 32 45 F3
    Master Code: 2042304227
    Phone type: RH-93, Software version: 6.93, Language Pack: IC
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
    Reading product code...
    Product Code:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Checking path: \Products\RH-93\
    No ini files found...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: rh930_nai6.01?
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Done!
    Feb 2009
    jhhj
    vây cho m xin file PM đi
  1. 110i cần giúp
    By domdomvang in forum BB5
    Trả lời: 12
    Bài viết cuối: 21-11-2012, 09:52
  2. 110i cần giúp
    By domdomvang in forum DCT4 - WD2
    Bài viết cuối: 19-11-2012, 08:22
  3. 110i cần ae giúp
    By nh0c_b0y_band in forum DCT4 - WD2
    Bài viết cuối: 02-08-2011, 14:50
  4. 110i xin giúp
    By sydungdtdd in forum DCT4 - WD2
    Bài viết cuối: 19-12-2010, 08:04
  5. 110i bệnh lạ cần giúp
    By cuong phone in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 21-07-2010, 19:25
