Kết quả 1 tới 3 của 3
    Thành viên chính thức mp_mobi's Avatar
    Jan 2009
    Mặc định 6220 rh-20 ??????
    máy 6220 mình rơi mất nguồn mình làm chân CPU,nguồn và flash cũng không lên.Cho vào hộp JAF chạy thì báo như vậy:
    JAF version 1.98.58
    Detected PKEY: 9001F2B2
    Card life counter: 99.21%
    Detected JAF INTERFACE version: 01.B0, Driver version: 20405, Library version: 30115
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-20\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-20\rh2040pra06.290
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-20\rh2040_06.29s
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-20\rh2040_06.29.ucp_s
    Languages in ppm: English,Chinese S,Malaysian
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-20\rh2040pra06.290
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rh-20\rh2040_06.29.ucp_t
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\products\rh-20\rh2040_06.29.ucp_v
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\products\rh-20\rh2040pra06.290
    Booting phone...
    MCU ID: 0x1130
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 00000000 <=> Flash -> not detected Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
    First 16 bytes: 00 00 81 03 00 01 81 80 00 04 41 86 01 06 40 84
    Flash ID is 0x00000000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 77
    Loader is ready...
    MSID: 84648817C0DE313EA71938999B
    MSID decoded: 00F4BAE9008379ECA8000000
    FAID: F54D95408C7AB13F5DA78164
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 017FFFFF...
    Erasing area: 01800000 - 019FFFFF...
    Erasing area: 01A00000 - 01FEFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Error cmd: 14!
    Addr: 01000000
    nhờ anh em diễn đàn chỉ giúp.cám ơn nhiều.
    Thành viên chính thức thanhpc14's Avatar
    Jun 2008
    kiếm ver cao chạy thư côi bạn
    Jan 2009
    ver cao nhất của no là bao nhiêu vậy thanhpc14
  1. 6220 cap cuu
    By duytoai in forum BB5
    Bài viết cuối: 16-10-2009, 15:38
  2. 6220 cap cuu
    By silly in forum DCT4 - WD2
    Bài viết cuối: 06-09-2009, 20:03
  3. 6220 lỗi pm
    By thuy_kieuhoa in forum DCT4 - WD2
    Bài viết cuối: 18-07-2009, 17:54
  4. xin sơ dồ câu tắt pa 6220
    By le hai in forum DCT4 - WD2
    Bài viết cuối: 08-01-2009, 11:47
