mình vừa nhận cây 3120 rin chưa bung,bị đập bể màn hình.máy mở không lên nguồn.bo hơi cong,dao động nguồn yếu.mình gắn vào jaf info như vầy:
MCU ID: 0x1120
FLASH ID0: 7E270100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06.31
25-11-05
RH-19
(c) Nokia.
HW version: 4835
PCI version:
UEM version: 1092
UPP version: 4384
RFIC version: 03122
DSP version: N5.20
LCD version: SED15G10ITO
PPM version: V 06.31
25-11-05
RH-19
(c) Nok
T
Production serial number: DCE278280
Product code: 0516553
Module code: 0202205
Basic production code: 0513172
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 356210009948709
IMEI spare to net: 3A 65 12 00 90 49 78 00
IMEI SV to net: 33 65 12 00 90 49 78 10 F1
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 2265700131
Phone type: RH-19, Software version: 06.31 , Language Pack: T
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-19.ini
Setting local mode...
Reading product code...
Product Code: 0516553
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-19\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.310
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31w
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_mxw1
Languages in ppm: English,Chinese S,Chinese T,Hindi
Done!
mình nghĩ là hở chân ic,nhưng làm lai ,upp + uem + flash + trung tần cũng y như trước.anh em nào biết giúp mình với? cám ơn trước nha
sau khi đóng ic mình đã chạy lại ok hết,nhưng màn hình không nỗi chử testmode,anh em tham khão nha.mới gặp lần đầu đó:
MCU ID: 0x1120
Algo is ready...
Done!
Phone Restarted...
Changing flashing settings...
Reading...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31t
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_mxt1
Languages in ppm: English,Vietnamese,Filipino,Chinese S,Chinese T
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\356210009948709_imei_back up_939307.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.310
Booting phone...
MCU ID: 0x1120
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E270100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: 1d
Loader is ready...
MSID: 84A40011EC00FB714193C5A456
MSID decoded: 0A6CBAE9008CF9A5A8000000
FAID: 7FE834C32D932BE006F4AF66
Operation took 0 minutes 8 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 01010000 - 0154FFFF...
Erasing area: 01680000 - 017EFFFF...
Erasing area: 01EB0000 - 01FEFFFF...
Operation took 0 minutes 49 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 32 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_mxt1
Booting phone...
MCU ID: 0x1120
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84B7C5596FB5A2111BF9D1C496
MSID decoded: D474BAE9008CF9A5A8000000
FAID: 3845FDE263E49B1518C152CE
Operation took 0 minutes 7 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01550000 - 0167FFFF...
Operation took 0 minutes 9 seconds...
Writing...
Operation took 0 minutes 2 seconds...
Restarting MCU...
Extracting Content Pack...
Running: (c) Nokia File Server
CNT Extract OK.
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31t
Booting phone...
MCU ID: 0x1120
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Writing...
Operation took 0 minutes 6 seconds...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 24 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: 356210009948709
Resetting PPC...
Done!
Unlocking...
ASIC: 2
SW version: 06.31
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 38
Setting test mode...
Setting FULL FACTORY...
Done!
