Kết quả 11 tới 20 của 26
    Thành viên chính thức Anminhgsm's Avatar
    check lại cable a nhé. ko đc thì làm cpu đi a. chúc may mắn
    Aug 2008
    Trích Được post bởi anhtuanmo Xem bài viết
    Detected PKEY: 90023A8C
    Card life counter: 98.98%
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.510
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.51mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh990_nai5.51mr
    Phone Type:
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.510
    Booting phone...
    MCU ID: 0xF543
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x28882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84ABE535C3D4B2C7778BDCA0D0
    MSID decoded: 3E4EBAE90004BBFFA8000000
    FAID: 36F3BC98317AF4C68E707981
    Operation took 0 minutes 7 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 1 minutes 6 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 14 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.51mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: AD 6E B6 0A 1B AE 0B E2 7D 48 6B E4 DB EE 65 04
    Loader is ready...
    MSID: 845C5ACE040315D6EB46F87103
    MSID decoded: 3E4EBAE90004BBFFA9000000
    FAID: 29601A0284E075EE0C76E7D1
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 21 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh990_nai5.51mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Operation took 0 minutes 3 seconds...
    Writing...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Flashing Done!
    Operation took 2 minutes 45 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Failed! Aborting!
    ban đầu máy bị contac sevic chạy lai máy báo vậy
    flash lại với ver cao hơn như 5.71 chẳng hạn co thể ok,chúc thành công
    yahoo : hoangtu_bongdem_1986
    phone : 0935 10 1986
    Thành viên chính thức anhtuanmo's Avatar
    mình thử hết dui nhung ko đc cám ơn ae nha để minh làm lại dùi bao kết quả sau
    Thành viên tích cực sonkien04's Avatar
    Mar 2008
    XUÂN TÍN CTY
    con này bạn kiếm cái cáp đút đit chạy thử đi , nhiều khi cáp ôp lưng chạy ko đc đâu bạn
    Bao Năm Lặn Lội Chốn Quê Người-Bây Giờ Nhìn Lại Tay Trắng Vẫn Như Xưa-Chuyên bán:Bếp Ga-Nồi Cơm Điện Quạt máy ĐT: 0973 70 80 80
    Thành viên mới thadunghua2003's Avatar
    Jul 2008
    mình co con 1200 dang lên nguôn nghe goi bình thương chek thì ok nhưng info thì không dươc mong cac bác giúp vói
    Jul 2008
    Angry
    1200 của tui dùng binh thương chek ok mỗi tội không info duoc mong các bác chỉ giáo
    Thành viên tích cực HưngMobile's Avatar
    Thốt Nốt_Cần Thơ
    1200 hay lỗi u nhé bạn,lắc nhẹ u xem sao(coi chừng ngủm)
    Nov 2007
    biên hòa - đồng nai
    bạn chạy lại đúng ver cũ cho nó là được thôi mà !! nếu bị CS ở model 1200 hay 1208 bạn thử check lại màn hình và sợi cable màn hình xem rồi hãy chạy lại dòng này không read imei được nên có khi vừa chạy vừa nín thở ở đoạn extract Content .....Failed hiện dòng báo này thì bạn nên chạy lại ver cũ cho nó nhé
    Thành viên tích cực shockcuteboy's Avatar
    Apr 2009
    Thiên Đàng
    Máy này giống bị chạy nhầm file quá vậy ta
    Khôi Mobile: Chuyên làm tất cả các dịch vụ liên quan đến DTDD. Đặc biệt: Biến máy sống thành máy chết trong 5s. Đ/C: Gò Đen_Long An:D
  10. ( shockcuteboy ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Mù Sửa ĐT (21-08-2009)
  11. #10
    Vi phạm nội quy BongMaTrongDem's Avatar
    Do Cáp Chạy Bằng Cáp Chân Xạc Bỏ Phin Vào
  1. xin ae xem ho gium cai log
    By ndmobile84 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 06-01-2011, 15:31
  2. Trả lời: 7
    Bài viết cuối: 13-10-2010, 10:58
  3. Trả lời: 6
    Bài viết cuối: 22-08-2010, 21:35
  4. nho chi gium rx va tx
    By hoanganh19021986 in forum Sửa chữa phần cứng
    Bài viết cuối: 21-10-2007, 22:19
