thư? kẹp nguồn di xem có nhận không bạn
<====em dẹp zai không các bác....
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.410
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.41aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.41aa
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.41md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.41md
Languages in ppm: English,Filipino,Vietnamase
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.410
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x01000000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: a6
Loader is ready...
MSID: 847FB667355639ADDB385499C2
MSID decoded: 3E4EBAE9004A327AA9000000
FAID: C7ACAD2178F0150943F1CE90
Operation took 0 minutes 11 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Writing...
Error cmd: 14!
Addr: 01000000
ae em oi cuu voi
