lúc mình info thì file tự động được chọn nhưng chỉ chọn các mục MCU,ADSP,APE variant,APE Uesd Disk. Còn các mục PPM nà CNT bị bỏ trống.
flash chạy một tí thì dừng lại báo lỗi.
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 4.64.40
27-04-2006
RA-2
(c) Nokia.
HW version: 6600
PCI version:
UEM version: 1092
UPP version: 8514
RFIC version: 0205
DSP version: E4.10A4.20
Production serial number: YBA562352
Product code: 0516778
Module code:
Basic production code: 0630742
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354305004526799
IMEI spare to net: 3A 45 03 05 40 25 76 09
IMEI SV to net: 33 45 03 05 40 25 76 29 F9
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 5240506465
Phone type: RA-2, Software version: 4.64.40, Language Pack: not available
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RA-2.ini
Setting local mode...
Reading product code...
Product Code: 0516778
Checking path: C:\Program Files\Nokia\Phoenix\Products\RA-2\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2_5221.4900
ADSP Flash file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.c01
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.l06
APE User Flash file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.u06
Languages in ppm: Italian,English,German
Done!
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\354305004526799_imei_back up_1553179.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2_5221.4900
Booting phone...
Phone didn't answer with TX line low after UEM reset!
Causes:
1. put a 27-33 pico capacitor in connector b/w mbus-gnd.
2. UEM damaged -> replace uem.
MCU ID: 0xDDDD
This MCU ID is not supported in chosen flash file...
Error booting phone...
xin ý kiến anh em.thanks nhiều nhiều.
 LinkBack URL About LinkBacks
			 xem dùm em log N9500
