Kết quả 1 tới 9 của 9
    Thành viên kỳ cựu hà_vũng tàu's Avatar
    Apr 2009
    Mặc định 2630 local mode cần giúp
    em nhân cây 2630 rớt nước giờ báo local mode em đã vệ sinh kỹ . em chạy phần mềm thì máy báo lổi .mong mấy anh em giúp. !!!
    Detected PKEY: 9002CF36
    Card life counter: 66.50%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 04.21
    16-08-07
    RM-298
    (c) Nokia
    HW version: 1000
    PCI version:
    UEM version: 1328
    UPP version: 12642
    RFIC version: 0500
    DSP version: GDSP_P06w45.v32
    LCD version: SUEZ
    PPM version: V 04.21
    16-08-07
    RM-298
    (c) Nokia
    V
    BT MCM version: 2222-v101
    Content Pack version: Content: v
    V 04.21
    16-08-07
    RM-298
    (c) Nokia
    Production serial number: DLM685714
    Product code: 0549387
    Module code: 0203304
    Basic production code: 0544206
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 358658011421024
    IMEI spare to net: 3A 85 56 08 11 24 01 02
    IMEI SV to net: 33 85 56 08 11 24 01 12 F0
    Master Code: 3115613145
    Phone type: RM-298, Software version: 04.21, Language Pack: V
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-298.ini
    Setting local mode...
    Reading product code...
    Product Code: 0549387
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-298\
    Checking path: \Products\RM-298\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-298\rm298__05.20.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-298\rm298__05.20.ppm_v
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-298\rm298__05.20.image_v
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\358658011421024_imei_back up_12431012.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\Products\rm-298\rm298__05.20.mcusw
    Booting phone...
    MCU ID: 0x0000
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    Thành viên tích cực tronghienmobile's Avatar
    Apr 2009
    local mode....pan này bạn xem kỹ đương btem vào ic nguồn đó bạn remove hoậc thay mới
    Thành viên tích cực huuson_0988's Avatar
    nó bị đút đường BSI đó anh.lấy sơ đồ về câu lại là ok thôi
    Thành viên chính thức nguyendien_81's Avatar
    Mar 2008
    http://www.gsmgovap.com
    bạn làm theo hình này xem sao bạn .
    SỐNG TRÊN ĐỜI CẦN CÓ 1 TẤM LÒNG TRỊNH CÔNG SƠN .
  5. ( nguyendien_81 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hà_vũng tàu (22-09-2009)
    Thành viên tích cực tuongmobil@_1987's Avatar
    NAM ĐỊNH
    chủ thớt đâu rui!
    không tiền đố mi làm nên...........!!!!!!!!!!!
    Apr 2009
    mấy huynh ơi em làm hêt cách rồi mà vẩn vậy .có cách nào khác nửa ko mấy hunh?
  8. #7
    V.I.P thinhtam's Avatar
    Nov 2008
    Trích Được post bởi ngocbinh_quangtri Xem bài viết
    máy hiện giờ lên nguồn ko?
  9. #8
    Apr 2009
    thanks mấy huynh em làm ok rồi!!!!!
  10. #9
    Thành viên mới hoangnghia09's Avatar
    May 2011
    e có con máy 6230 bị localmode xin các bác giúp em vói
  1. c3-00 hiện test mode hoặc local mode
    By hovietluy in forum BB5
    Bài viết cuối: 12-12-2012, 16:36
  2. Trả lời: 0
    Bài viết cuối: 22-06-2011, 06:45
  3. vấn đề local mode,test mode...của dòng dct4
    By quocchuong566 in forum DCT4 - WD2
    Bài viết cuối: 25-11-2010, 21:59
  4. 6300 , 3110c local mode test mode solution .
    By jerrylevu in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 25-01-2010, 12:06
  5. 6120c test mode local mode solution
    Bài viết cuối: 23-12-2009, 14:09
