Kết quả 11 tới 20 của 20
    Thành viên tích cực trung83's Avatar
    Aug 2007
    từ đầu máy có nguồn nhưng mất sóng.em nạp chạy lai mềm.thì nó báo như vậy nè " phone restricte" log chạy jaf của nó nè
    flashMCU ID: 0x2031
    FLASH ID0: 2C7E0001 <=> SPANSION -> 72NS128N Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Setting local mode...
    Reading product code...
    Product Code:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-74\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-74\
    No ini files found...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: rm74__5.40.image_?
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Reading...
    Phone Type: RM-74
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.400
    CNT Flash file: NONE
    Phone Type: RM-74
    Reading...
    Phone Type: RM-74
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.200
    Phone Type: RM-74
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.20v
    Languages in ppm: English,Vietnamese,Chinese S,Chinese T
    Phone Type: RM-74
    CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.20.image_v
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\359356002738014_imei_back up_1320299.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.200
    Booting phone...
    MCU ID: 0x2031
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x7E2C0100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 10
    Loader is ready...
    MSID: 84D8D662AC9A96D2892AA4D4DC
    MSID decoded: CF4FBAE900C33DA8A9000000
    FAID: 459130ABDA2A075352E3438A
    Operation took 0 minutes 8 seconds...
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01000000 - 0101FFFF...
    Erasing area: 01020000 - 017BFFFF...
    Erasing area: 01F20000 - 01FDFFFF...
    Operation took 0 minutes 45 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 18 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.20.image_v
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8424B3462B83A8486BE7F40377
    MSID decoded: 1C15BAE300C33DA8AD0005BD
    FAID: 23A61015CD238CEF2E5E69CF
    Operation took 0 minutes 9 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01C00000 - 01F1FFFF...
    Operation took 0 minutes 16 seconds...
    Writing...
    Writing converted flash to 128k page
    Restarting MCU...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract Skiped.
    Operation took 0 minutes 0 seconds...
    PPM: C:\Program Files\Nokia\Phoenix\products\RM-74\rm74__5.20v
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader size is 0x7518; Loader chk: f0
    Loader is ready...
    MSID: 8440A3E0108AA3E01CCA1413FB
    MSID decoded: 3E4EBAE900C33DA8A8000000
    FAID: DD7FF829ACBF582018D949A6
    Erasing PPM...
    Erasing area: 017C0000 - 01BFFFFF...
    Operation took 0 minutes 23 seconds...
    Writing...
    Operation took 0 minutes 21 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 51 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-74, Software version: 5.20
    IMEI: 359356002738014
    Product Code:
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    V.I.P ThienKim GSM™'s Avatar
    Feb 2009
    Thành phố Dệt
    Trích Được post bởi trung83 Xem bài viết
    Đến đó OK rồi .BI giờ tick vào chỗ WRITE Pm >>click service rồi chọn file pm chờ nó chạy xong, click unlock rồi chọn file MCU 5.20( như log FLASH) là OK.
    Máy đã unlock đâu mà chả báo như vậy
    Aug 2007
    máy có nguồn nhưng mất sóng.em chạy lai nó bi vậy đó anh."phone restricter" còn log chạy em đưa log ở trên đó anh
    Aug 2007
    máy 6030 của em có nguồn nhưng không có sóng.em nạp flash rối có nguồn nhưng bỏ sim vào nó báo "phone restricterd " vậy là sao hả các anh
    Thành viên tích cực hungmobile_90's Avatar
    bác nói kĩ hon di.flash thế là ổn rùi còn j
    V.I.P HẢI THỌ's Avatar
    Apr 2008
    biên giới campuchia!!
    Talking
    Trích Được post bởi hungmai_mobile Xem bài viết
    thì bây giờ bạn chỉ cần tích vào unlock là ok oai!nó báo là: đã hạn chế dt ấy mà!làm đi bạn ok thui!
    Dtdđ-VŨ HÀ
    0916.775.115
    Thành viên mới sinh_dt's Avatar
    Dec 2008
    hihi cảm on anh nhé em lam duoc rối
    Thành viên mới laivanlong's Avatar
    Sep 2010
    Giúp mình với mình có con máy 110y tự nhiên mất nguồn
    ĐÔ LƯƠNG _ NGHỆ AN
    Trích Được post bởi laivanlong Xem bài viết
    pó tay với ông bạn này luôn nói chẳng rõ ràng gì cả mà muốn người ta giúp . mà có muốn giúp cũng chẳng giúp đc . nếu muốn giúp thì cũng phải nói bênh hiện tại như thế nào như kẹp nguồn như thế nào cho vào box check ra sao ? còn nếu k0 phải là thợ kỹ thuật thì tốt nhất mang ra cửa hàng ĐT thợ họ làm cho
    Feb 2009
    Thành phố Dệt
    help me.các anh oi
    Đập cho nó cái Pm rồi UNLOCK>>chắc sẽ OK.
  1. 6030 gọi mất nguồn
    By baolinhmobile in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 28-06-2010, 21:35
  2. 6030 mở nguồn có vấn đề
    By huuthien in forum DCT4 - WD2
    Bài viết cuối: 22-03-2008, 23:29
  3. 6030 mất nguồn
    By Dyna Tac in forum DCT4 - WD2
    Bài viết cuối: 10-03-2008, 23:38
  4. 6030 mất nguồn
    By QuốcBình in forum DCT4 - WD2
    Bài viết cuối: 28-08-2007, 19:00
  5. Trả lời: 7
    Bài viết cuối: 09-05-2007, 09:47
