    Thành viên chính thức pnkhiem's Avatar
    Sep 2007
    Mặc định 6230i rớt mất nguồn, xin cứu gấp
    mình mới nhận cây 6230i làm rớt, mất nguồn . kẹp nguồn bấm kim vọt lên 20 ma sau đó rớt xuống còn lại 3 vạch , nằm ở đó khoảng 3 phút , rớt về 0 . không lên nguồn. bỏ vô HWK chạy 2 lần . lần 1 khác, lần thứ hai khác . xin các cao huynh chỉ giúp. cám ơn trước.
    6230i (check được, nhưng infn không đươc))
    plash lần thứ 1:
    1st Boot: Ok, TIKU, UPP: 2051 [Rm-72] [2.0.8.0]
    2nd Boot: te_2nd.fia, Ver: 4.76.0
    Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB
    Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256
    Algorithm: te_amd_b.fia, Ver: 4.76.0
    Algorithm Ok, MSID: 840D4707F0A8010FA4A4C892F8
    Decoded MSID: 71C3BAE9-00B31371-A8000000
    Encoded FAID: 00CA1B7B-C2162356-9736BF31
    IMAGE: rm72_73_11003.700
    Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
    Area2: 0x00010000-0x009FFFFF Erased, Time: 01:13
    Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:08
    Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:31
    MCU Flashing Completed, Time: 00:56
    FLASH_FILE_MM_TYPE: TIKU EIJA SSR [NAND]
    FLASH DEVICE NOT SUPPORTED
    Check Product, Use newer Flash Update Pack
    Algorithm: te_essr.fia, Ver: 4.76.0
    2nd Boot Error:
    Error Data1:
    00000000: 9F 01 04 00 EC 00 E8 22 00 00 21 7D 10 00 02 EC ......."..!}....
    00000010: 00 10 00 00 00 00 00 09 00 04 00 00 01 00 00 00 ................
    00000020: 00 00 00 00 06 00 00 01 00 00 00 00 00 00 00 00 ................
    00000030: 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 9F ................
    Error Data2:
    00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00000010: 00 00 00 00 09 00 04 00 00 01 00 00 00 00 00 00 ................
    00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
    00000030: 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 9F D3 72 00 ..............r.
    Before taking screenshot, expand this window !
    Plash lại lần thứ 2:
    Area2: 0x00010000-0x009FFFFF Erased, Time: 01:12
    MCU Flashing Completed, Time: 01:49
    FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND]
    Algorithm: te_oncsm.fia, Ver: 4.76.0
    IMAGE: rm72_73_110M_03.70.ucp_v
    Mass Memory Erased, Time: 00:01
    CNT Flashing Completed, Time: 00:53
    Extracting Contents Package ...
    Init Local Mode Failed
    Contents Package Extracting Failed:
    2nd Boot Error:
    Error Data1:
    Error Data2:
    Thành viên tích cực ĐìnhThắngMobile™'s Avatar
    GSMobifone
    nhìn log hwk không quen lắm_bạn cho sang jaf cho dễ nhìn
    Sep 2007
    jaf không chạy được như HWK , VỚI LẠI, mình không có jaf , chỉ chạy bản crack thôi . không rành lắm. để chạy thử cái coi. chờ chúc
    Sep 2007
    chạy JAF (CRACK)không được, chạy tiếp HWK lần thứ,4,5.. qua ngọt luôn nhưng vẫn không lên nguồn . khi info vẫn không được, không full factory đc, không initsimclock được.
    Lần thứ 3 (ok)
    Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:09
    CNT Flashing Completed, Time: 00:52
    IMAGE: rm72_73_110M_03.70v
    Mass Memory Erased, Time: 00:00
    PPM Flashing Completed, Time: 01:06
    Flashing Completed, Rebooting Mobile
    Thành viên tích cực trantuyen_mobile's Avatar
    Jul 2008
    KIÊN GIANG MÌNH ĐẸP LẮM
    cái này bạn nên kiếm files chuẩn bỏ wa box khác cao hơn chạy chắc là ok mà đừng làm cứng vội nha ban, chúc thành công.
    KÍNH VỢ ĐẮC THỌ
  1. 6230i mất nguồn xin cứu
    By tranquocthanh83 in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 08-05-2010, 16:21
  2. 6230i hao nguồn chờ
    By khanhhung99 in forum DCT4 - WD2
    Bài viết cuối: 08-10-2009, 09:31
  3. Trả lời: 15
    Bài viết cuối: 27-07-2009, 16:32
  4. 6230i ăn nguồn chờ
    By HÀ GIANG GSM in forum DCT4 - WD2
    Bài viết cuối: 27-07-2009, 16:13
  5. máy 6230i mất nguồn
    By namchaychao in forum DCT4 - WD2
    Bài viết cuối: 18-12-2007, 14:29
