em có con may 1208 chay phan mêm nó không đọc được ra i mây các bác chĩ em với
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: D:\RH-105\rh105_05.710
Phone Type:
PPM Flash file: D:\RH-105\rh105_05.71mr
Phone Type:
CNT Flash file: D:\RH-105\rh1050_nai5.71mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\RH-105\rh105_05.710
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84B8CC9005CE5FD0E962D11792
MSID decoded: 3E4EBAE9005697ADA8000000
FAID: D049FC1F62CF66D44D90DD03
Operation took 0 minutes 7 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 5 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: D:\RH-105\rh105_05.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 21 seconds...
Writing...
Restarting MCU...
CNT: D:\RH-105\rh1050_nai5.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 43 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 5.71
IMEI: ???????????????
Product Code:
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Done!
				Gửi log thôi, còn chờ gì nửa bạn!IMEI: ???????????????
Trần Hoàng Thiên
sen cho nó 1 log thôi bạn
1 log la xong
có vậy mà cũng hỏi hả bác.kiếm cho nó 1 log là ok ngay thôi
ai có cho anh ý xin 1log đi hix
