máy bị trắng màn+treo không gọi được.đã làm lại chân upp và thay dao động
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Reading product code...
Product Code: 0546885
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84AEC4BD71DFB9A1E3B099947C
MSID decoded: 3E4EBAE900C2F169A9000000
FAID: 2C6BF927A61AFE14903FF3C5
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 17 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84FC461A5D385AA5A851B532D4
MSID decoded: 3E4EBAE900C2F169A8000000
FAID: 17C901CF2E2197AE9C47C9FC
Operation took 0 minutes 4 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 25 seconds...
Writing...
Operation took 0 minutes 7 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 840B84BAFE42F4DBF67404FF89
MSID decoded: 3E4EBAE900C2F169AA000000
FAID: B9EC5DBCAB20F9C4D9508E11
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 29 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 5.80
IMEI: 353108027623101
Resetting PPC...
Done!
