MCU ID: 0x0120
FLASH ID0: 7E220100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.02
26-05-03
NHM-8
(c) NMP.
HW version: 0678
PCI version:
UEM version: 8
UPP version: 288
RFIC version: 0300
DSP version: P3.04-@
LCD version: PHILLIPS 0
PPM version: V 5.02
26-05-03
NHM-8
(c) NMP.
S
Production serial number: 2FB625156
Product code: 0509991
Module code: 0202017
Basic production code: 0507061
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: 2?129032003 16:04:48??????2F??0???????????????????
Default SN type: 2?129032003 16:04:48??????2F??0???????????????????
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 1F F9
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 5013663745
Phone type: NHM-8, Software version: 5.02, Language Pack: S
User code: 12345
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_NHM-8.ini
Setting local mode...
Reading product code...
Product Code: 0509991
Checking path: C:\Program Files\Nokia\Phoenix\Products\NHM-8\
Checking path: \Products\NHM-8\
No ini files found...
Done!
cái lop em đó em thay con nguồn khác imel ??????
cho em hỏi JAF có ret ASK được ko vậy cho em xin hướng dẫn luôn ??
