hic mình không biết đưa log lên giúp thì giúp cho trot nhe bạn chỉ mình cách đua log lên dùm nhe
giúp thì giúp cho trot nhe bạn mình không biết cách đua log lên bạn chỉ mình cach đưa log lên nhe a
tting MCU ID
MCU ID: 0x2142
FLASH ID0: 277E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06.31
25-11-05
RH-19
(c) Nokia.
HW version: 3040
PCI version:
UEM version: 1092
UPP version: 8514
RFIC version: 03122
DSP version: N5.20
LCD version: X4
PPM version: V 06.31
25-11-05
RH-19
(c) Nok
S
Production serial number: M2K766921
Product code: 0516543
Module code: 0202448
Basic production code: 0518626
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: m?????????????????????????????????????????????????
Default SN type: m?????????????????????????????????????????????????
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 1F F1
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 5013663745
Phone type: RH-19, Software version: 06.31 , Language Pack: S
User code: 55555
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-19.ini
Setting local mode...
Reading product code...
Product Code: 0516543
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-19\
Checking path: \Products\RH-19\
No ini files found...
Done!
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.310
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31c
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_xc1
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31b
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_cpl
Languages in ppm: English,German,French,Polish,Romanian,Hungarian
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31t
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_glo
Languages in ppm: English,Vietnamese,Filipino,Chinese S,Chinese T
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_mxt1
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\???????????????_imei_back up_2132410.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.310
Booting phone...
MCU ID: 0x2142
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E270100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: 1d
Loader is ready...
MSID: 84F6A68B0E4DE469C5D2EBA3EA
MSID decoded: 0A6CBAE90045E6B1A8000000
FAID: B2EF98FB4B226B9EE849D73C
Operation took 0 minutes 6 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 01010000 - 0154FFFF...
Erasing area: 01680000 - 017EFFFF...
Erasing area: 01EB0000 - 01FEFFFF...
Operation took 0 minutes 48 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 33 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31.ucp_mxt1
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84F8DF5123FAA2428B3239E007
MSID decoded: D474BAE90045E6B1A8000000
FAID: 6FD9461EDE72BA134AC0CCAD
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01550000 - 0167FFFF...
Operation took 0 minutes 8 seconds...
Writing...
Operation took 0 minutes 3 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Extracting Content Pack...
Running: (c) Nokia File Server
CNT Extract OK.
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-19\rh19__06.31t
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 29 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: ???????????????
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Unlocking...
ASIC: 2
SW version: 06.31
Phone is not in LOCAL MODE or TEST MODE, or imei is damaged...
Failed! Aborting!
Done!
đó pac giúp mình môt log đi cám ơn bác trươc nhe
bây giờ info nó ra như thế này rồi nè mấy bác ơi Getting MCU ID
MCU ID: 0x2142
Error in MSG id...
vào đây down jaf 198.62 về:SUPPORT SAIGONMOBILE.VN
vào đây lấy crack:4shared.com - chia sẻ và lưu trữ - tải xuống tập tin trực tuyến OGM_JAF_PKEY_Emulator_v 5.exe
về bung jaf cài ra driver rồi mở crack lên bấm go xài thôi( connect box jaf hoặc không có lấy cái ufs hay nbox gì cũng được chạy tuốt)
jaf crack thì nó cũng xài như jaf xịn thôi có điều là sx4 ko được![]()
