máy vào nước mất nguồn chạy pm có lỗi đã thay cpu,flast mà chạy vẫn báo lỗi vậy,ic nguồn thì đổ keo,không giám đụng tới nó:log nó nè anh em ai biết giúo đỡ em pan này nha!!! thank các anh em nhiều !!!!!
Getting MCU ID
MCU ID: 0x1052
FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed! Aborting!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-72\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.89v
Languages in ppm: English,Vietnamese,Chinese S,Chinese T
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.89.ucp_v
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890
Booting phone...
MCU ID: 0x1052
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Boot size is 0x2398
Boot is ready...
Flash ID is 0x22E800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
Loader size is 0x84A0; Loader chk: 4c
Loader is ready...
MSID: 848A6C252A130DEE50364E8BC0
MSID decoded: 80B0BAE90080E460A8000000
FAID: F444EA3BE75B39610A63762E
Operation took 0 minutes 19 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 009FFFFF...
Erasing area: 00A00000 - 00B3FFFF...
Erasing area: 00B60000 - 00FAFFFF...
Operation took 1 minutes 59 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 54 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.89.ucp_v
Booting phone...
MCU ID: 0x1052
Boot size is 0x2398
Boot is ready...
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia
Loader size is 0x9858; Loader chk: b3
Loader is ready...
Operation took 0 minutes 17 seconds...
Erasing Content Pack...
Mass Memory Device Detected...
MM Bus Configured...
Formating MM...Format failed!
