Getting MCU ID
MCU ID: 0x1052
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-12\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50a
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_a
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500
Booting phone...
MCU ID: 0x1052
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Boot size is 0x2398
Boot is ready...
Flash ID is 0x22F800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
Loader size is 0x84A0; Loader chk: 38
Loader is ready...
MSID: 84D5DFB18547D0D343E0818302
MSID decoded: B03FBAE9001ED102A9000000
FAID: 97633A1D5278C836AF5F115B
Operation took 0 minutes 10 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 007FFFFF...
Erasing area: 00800000 - 0093FFFF...
Erasing area: 00B60000 - 00FEFFFF...
Operation took 2 minutes 7 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 51 seconds...
Restarting MCU...
NAND Format FAILED!!!
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_a
Booting phone...
MCU ID: 0x1052
Boot size is 0x2398
Boot is ready...
Loader is ready...
MSID: 84FA4290BB4ECB3970EE977BD6
MSID decoded: 3E4EBAE9001ED102A9000000
FAID: 8CD8741CD30459F66542351D
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 00940000 - 00B3FFFF...
Operation took 0 minutes 18 seconds...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50a
Booting phone...
MCU ID: 0x1052
Boot size is 0x2398
Boot is ready...
Loader is ready...
Erasing PPM...
Operation took 0 minutes 19 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 5 minutes 50 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Nhờ ae cao thủ xem dùm em cái log nokia 6230 thường em chạy moi cách mà sao không done được. em xin cảm ơn ae cao thủ
