e có con 1202 chết nguồn em thay con nguồn va flas của 1202 khác va chạy lai pm thi contac ma unlock thì không được?toàn failed.ae nào đa làm rồi xin chỉ dùm e với.thak các sư huynh nhìu!
Phone type: RH-112, phần mềm phiên bản: 03,10
IMEI: 358261034005716
Mã sản phẩm: 0593282
Resetting UBND tỉnh ...
Thiết FULL FACTORY ...... Thiết lập chế độ kiểm tra ...
Thiết lập Full MÁY ...
Operation took 0 phút 8 giây ...
Làm xong!
Làm xong!
Powering the phone ...
Mở khóa ...
ASIC: b
SW version: 03,10
Unlock không được hỗ trợ!
Thất bại! Aborting!
Làm xong!
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.00
14-11-08
RH-112
(c) NMP
HW version: 1001
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_08w31_UPP
LCD version: WIN:SERI:8a
NT7542
PPM version: V 03.00
14-11-08
RH-112
(c) NMP
MR
ADSP SW version: V 03.00\n14-11-08\nRH-112\n(c) NMP\nmr
Production serial number: DXM261466
Product code: 0563390
Module code: 0203762
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356920030202559
IMEI spare to net: 3A 65 29 00 03 02 52 05
IMEI SV to net: 33 65 29 00 03 02 52 15 F4
Master Code: 6037711570
Failed reading simlock data...
Phone type: RH-112, Software version: 03.00, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code: 0563390
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
Phone Type:
MCU Flash file: H:\rh112_004.030
Phone Type:
PPM Flash file: H:\rh112_004.03mr
Phone Type:
CNT Flash file: H:\rh1120_nai04.03mr
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: H:\rh112_004.030
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84410E6BD14414F1C0F6A3A86C
MSID decoded: 3E4EBAE90089C945A9000000
FAID: FFC3018D64FC5F43F4FE751C
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 5 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: H:\rh112_004.03mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 848C356AE2B9699E7277A6631D
MSID decoded: 3E4EBAE90089C945A8000000
FAID: E55E2B6F26B139DF59B9F372
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 20 seconds...
Writing...
Operation took 0 minutes 7 seconds...
Restarting MCU...
CNT: H:\rh1120_nai04.03mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Operation took 0 minutes 6 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 13 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-112, Software version: 04.03
IMEI: 356920030202559
Resetting PPC...
Done!
Setting test mode...
Setting FULL FACTORY...
Done!
Unlocking...
ASIC: b
SW version: 04.03
Unlock not supported!
Failed! Aborting!
trờ oi làm xong gi đó
anh em oi em co con nokia co imei 350604400278151 như thế bị mất chân sim em muốn tim sơ đô câu mà k biết tên máy là gì anh em giúp em vơi.con nay nó giống con 6230 (dòng dct4 duy nhất có thẻ nhớ) đó các anh
