Kết quả 1 tới 9 của 9
    Vi phạm nội quy tuyetnhi_2007's Avatar
    Mặc định xem giúp em cai log 6230
    Getting MCU ID
    MCU ID: 0x1052
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500
    Booting phone...
    MCU ID: 0x1052
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x22E800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 4c
    Loader is ready...
    MSID: 84A890FC4688F39FDCE3D63FFE
    MSID decoded: B03FBAE900821151A9000000
    FAID: BD90713622E8A2382416BB80
    Operation took 0 minutes 20 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 007FFFFF...
    Erasing area: 00800000 - 0093FFFF...
    Erasing area: 00B60000 - 00FEFFFF...
    Operation took 2 minutes 1 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 47 seconds...
    Restarting MCU...
    NAND Format FAILED!!!
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_v
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    MSID: 845220F258D70FB65568526901
    MSID decoded: 3E4EBAE900821151AA000000
    FAID: 2595951D4E81B0C6DFAB85F2
    Operation took 0 minutes 19 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 00940000 - 00B3FFFF...
    Operation took 0 minutes 17 seconds...
    Writing...
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50v
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    MSID: 84931E717D76C236C4D1C6E89B
    MSID decoded: 3E4EBAE900821151A8000000
    FAID: 0C1333B44E03DAD44F03DD95
    Erasing PPM...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 6 minutes 18 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Log Nbox
    1st Boot: Ok, TIKU, UPP: 1052 [Rh-12] [2.0.9.0]
    2nd Boot: te_2nd.fia, Ver: 4.76.0
    Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB
    Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256
    Algorithm: te_amd_b.fia, Ver: 4.76.0
    Algorithm Ok, MSID: 84A890FC4688F39FDCE3D63FFE
    Decoded MSID: B03FBAE9-00821151-A9000000
    Encoded FAID: BD907136-22E8A238-2416BB80
    IMAGE: rh12_28_11005.500
    Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
    Area2: 0x00010000-0x007FFFFF Erased, Time: 01:06
    Area3: 0x00800000-0x0093FFFF Erased, Time: 00:10
    Area4: 0x00B60000-0x00FEFFFF Erased, Time: 00:37
    MCU Flashing Completed, Time: 00:47
    IMAGE: rh12_28_11005.50.ucp_v
    Area1: 0x00940000-0x00B3FFFF Erased, Time: 00:16
    CNT Flashing Completed, Time: 00:08
    Extracting Contents Package ...
    Init Local Mode Failed
    Contents Package Extracting Failed:
    ko sạc em wr pm lại thì sạc dc rồi ..em gắn vào sạc thì lúc em lấy ra thấy nó hiện lên ma code em tắt nguồn mở lên nó báo contracsevic em chạy lai nó báo như vậy ..em chạy nhiều ver rồi giờ em hong biết làm gì nhờ anh em giúp đở em cám ơn nhiều
    Thành viên chính thức bomngoc's Avatar
    unlock đi cho nó phát coi sao anh
    anh ạ từ đầu em ko unlock em chạy lại nó báo như vậy là máy chết rồi giờ làm sao unlock dc anh ạ .. bây giờ em phải làm gì nhờ anh em 4r giúp đỡ em cám ơn nhiều
    Thành viên chính thức tronggsm's Avatar
    anh thu chế độ blutooth xem sao anh ạ
    Phone: 0989402123
    Zalo :0989402123
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    mang sang hộp khác chạy lại cho nó đi anh
    krongpac_daklak
    xoá full chạy lại đi bạn
    anh ạ em chưa biết cách bật chế độ blutooth anh hướng dẩn cách làm cho em dc chứ ..em cám ơn nhiều
    cái này chắc phải làm đến con UEM thôi anh ơi,nó ko đưa máy vào loacal mode được nên ko thể flash thanh công
    Thành viên tích cực van_ninh_mobile's Avatar
    Đồng Nai
    Trích Được post bởi thanhcong mobile Xem bài viết
    cứ làm nhưng bác này là ok ,mình vừa làm xong 1 cây ..
  1. 6230 cần giúp đỡ
    By hiepthay in forum BB5
    Bài viết cuối: 19-04-2011, 17:40
  2. Giúp em cây 6230 nầy với
    By toilatoi83 in forum DCT3-DCTL
    Bài viết cuối: 23-10-2010, 18:13
  3. 6230 bệnh lạ cần giúp đỡ!
    By pinkin1982 in forum DCT4 - WD2
    Bài viết cuối: 09-01-2009, 20:38
  4. 6230 cần anh em giúp đỡ
    By dungxi in forum DCT4 - WD2
    Bài viết cuối: 02-11-2008, 19:14
  5. 6230 cần giúp đỡ
    By thanhvietnokia in forum DCT4 - WD2
    Bài viết cuối: 03-05-2008, 14:23
