mình có cây 2600 viet pm bây giờ mở nguồn không lên đã chạy ct nhưng báo lỗi hoài
Getting MCU ID
MCU ID: 0x1201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-59\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-59\rh59_04.420
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-59\rh59_04.42ma
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-59\rh590_nai4.42ma_2
Languages in ppm: English,Chinese S,Chinese T,Vietnamese,Filipino
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-59\rh59_04.420
Booting phone...
MCU ID: 0x1201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: c6
Loader is ready...
MSID: 84536CF6DE586A3DDF8F9E496B
MSID decoded: 3E4EBAE9001449B7A8000000
FAID: 3CD2E1CD02AF3C7445732C69
Operation took 0 minutes 6 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017B0000 - 017EFFFF...
Erasing area: 01FB0000 - 01FEFFFF...
Operation took 0 minutes 28 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 10 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-59\rh59_04.42ma
Booting phone...
MCU ID: 0x1201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84B0C66943ABD64C3FC9B241A8
MSID decoded: 3E4EBAE9001449B7A9000000
FAID: 789F2E3164E3F8983EE5A8C2
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01190000 - 0119FFFF...
Erasing area: 011A0000 - 0136FFFF...
Operation took 0 minutes 13 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-59\rh590_nai4.42ma_2
Booting phone...
MCU ID: 0x1201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01370000 - 013AFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 47 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
