Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: 32 0E 4C 8A AF D4 55 C3 78 0E 03 E2 66 4B CE F9
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10ie
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10ie
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84DDC23E5C662324A876082ACA
MSID decoded: 3E4EBAE90056CE1CA8000000
FAID: FEF336759EFB6DC010DEC3BC
Operation took 0 minutes 12 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 11 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10ie
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
First 16 bytes: 00 00 02 0A 00 10 03 40 C0 00 04 00 20 80 60 10
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 22 seconds...
Writing...
Operation took 0 minutes 6 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10ie
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84A012972C49EB3679760E468D
MSID decoded: 3E4EBAE90056CE1CA9000000
FAID: 7E955D2EFD5F7E01AC74001A
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 4 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 53 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
