Em có cây 1200 tình trạng ban đầu thợ khác mang đến máy bật nguồn hiện chử nokia rồi đứng im. em bỏ vào box chạy lại ver khác write pm+factory nhưng đến unlock thì không được.em đã xoá funll nạp lại rồi.bây giờ thì bị contac không info được.mong các a giúp đỡ.em xin chân thành cảm ơn. đây là log củ nó ah .etting MCU ID
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_04.510
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_04.51mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai4.51af
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_04.510
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 844B678833C80FAED7BFAA741B
MSID decoded: 3E4EBAE900CC0562A8000000
FAID: B4C013F4F7EE52CC403548EF
Operation took 0 minutes 11 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 14 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 13 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_04.51mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Operation took 0 minutes 10 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 24 seconds...
Writing...
Operation took 0 minutes 6 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai4.51af
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 4 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 44 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 4.51
IMEI: 354873026845661
Product Code: 0546370
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 7 seconds...
Done!
Done!
Powering the phone...
Unlocking...
Failed! Aborting! Asic 00
Done!
