Cái này nói nhìu rùi mà bác ơi
Default SN type:
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 3F F5
không có gì là chuẩn mực bác mà không sene log thì không bao giờ chuẩn mực
linhsaker (06-01-2010)
gửi cả cái mình chạy hả anh
yahoo : x4uz4j_0mh4n_ch4p_nh4n_c0d0n_vkl
sđt 097.885.1989 ----- 0128.741.1989
em không biêt vào chỗ nào lấy lại imei anh ơi
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.400
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.40aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.40aa
Languages in ppm: English,Dannish,Norwegian,Swedish
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.40me
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.40me
Languages in ppm: English,Bahasa Ind,,Chinese S,Chinese T
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.40md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.40md
Languages in ppm: English,Filipino,Vietnamase
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.400
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: c6
Loader is ready...
MSID: 8438D1C2F2882F439984A39F1E
MSID decoded: 3E4EBAE9005F7844A9000000
FAID: EA0417C49BF2EAC8EC18C5EB
Operation took 0 minutes 8 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 28 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 12 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.40md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 8499201E3BA949E9D613BDF482
MSID decoded: 3E4EBAE9005F7844A8000000
FAID: 1C3B6470AC4D743F2565FC81
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.40md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Operation took 0 minutes 7 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 1 minutes 36 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-93, Software version: 6.40
IMEI: ???????????????
Product Code: 0525400
Resetting PPC...
Done!
Setting test mode...
Setting FULL FACTORY...
Done!
Powering the phone...
Unlocking...
ASIC: 2
SW version: 6.40
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.400
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 01
MCU ID: 0x2201
Algo is ready...
Erasing area: 01140000 - 0115FFFF...
Unlocking...
Simlock data rejected! Code: 0x13
Failed! Aborting!
em unok báo thế này a.
35310902349859
Rpl của bạn nè :http://www.4shared.com/file/18944692...902349859.html
342 Nguyễn Công Trứ Thốt Nốt-CầnThơ
ĐT:0919851336_ yh: 0919851336@yahoo.com
áic có 1 số ak anh em tìm mãi mới đc số 2 anh ak
cảm ơn nh nhìu nha
