khi chạy bit 1 chậy dưới lại chạy okmình nhận cây 1110i tình trạng máy ban đầu như sau: kẹp nguồn thì lên, lắp pin không lên khi kẹp nguồn khởi động máy không có chuông ko có sóng, mình đem flash lại thì máy báo lổi như sau ( trich dẩn sau) sau đó mình thay mấy con tụ trên đường BSI thì máy vẫn vậy. bây giờ ko flash được nên máy đã đie. mong anh em góp y giùm.
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: C4 27 CB 5F 3A D7 DD F6 7D 27 CB 5F 3A D7 DD F6
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
Languages in ppm: English,Filipino,Vietnamase
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
First 16 bytes: E0 27 CB 5F 2A D7 DF F6 7D 27 CB 5F 2A D7 DF F6
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: bb
Loader is ready...
MSID: 845F2A4AEDA9FED7FF6E940581
MSID decoded: 3E4EBAE900D70095AA000000
FAID: 382DC6F2672AA9D06992BF2F
Operation took 0 minutes 13 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 45 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 17 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
First 16 bytes: E0 27 8B 5F 2A D7 DF F6 7D 27 CB 5F 2A D7 DF F6
Loader is ready...
Operation took 0 minutes 12 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 18 seconds...
Writing...
Operation took 0 minutes 14 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
First 16 bytes: C4 27 CB 5F 2A D7 DD F6 7D 27 CB 5F 3A D7 DF F6
Loader is ready...
MSID: 848525B1B8F0750F84C0BD218A
MSID decoded: 3E4EBAE900D70095A8000000
FAID: 53D57CBBC23603370EE5D3D0
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 51 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
