AE xem hộ log rh51 7610 cho mình với Thahk nhìu
MCU ID: 0x1081
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
Master Code: 7724472020
Failed! Aborting! MCUVER
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02
Languages in ppm: English,French,German (Euro A)
Setting local mode...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\357070004225324_imei_back up_1823113.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Boot size is 0x10D8
Boot is ready...
Flash ID is 0x22F800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: ac
Loader is ready...
MSID: 8441661828F32741780D275D56
MSID decoded: 3E4EBAF700569BDDA9000000
FAID: 7B96416FF7DB77BCA3E5BA9F
Operation took 0 minutes 20 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 0287FFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 4 minutes 52 seconds...
Writing...
Perm. Data Restore OK
Operation took 5 minutes 17 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02
Booting phone...
MCU ID: 0x1081
Boot size is 0x10D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 21 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 02A00000 - 02C9FFFF...
Operation took 0 minutes 30 seconds...
Writing...
Operation took 0 minutes 35 seconds...
Restarting MCU...
Flashing Done!
Operation took 12 minutes 3 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...MCUVER
 LinkBack URL About LinkBacks
			 AE cứu 3110c cho mình với
