Kết quả 1 tới 10 của 11
    Thành viên mới hmmx4's Avatar
    Apr 2010
    Mặc định 1209 rơi nước,nguồn kô có dao động.
    con này em làm lại U và Lash rùi,nhưng khi kẹp nguồn kô có dao động nos lên tới gần 1 thì đứng im.em chạy phần mềm thì ntn.
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 260600EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Phone Type:
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_05.910
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_05.91mc
    Languages in ppm: English,Thailand
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai5.91mc
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_05.910
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x0626EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: 3a
    Loader is ready...
    MSID: 848561D0E29E74C5B01548E84C
    MSID decoded: 3E4EBAE900D0BD66A8000000
    FAID: 021FB3A8D81D743BB9AA56AB
    Operation took 0 minutes 11 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 0 minutes 28 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 14 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_05.91mc
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 9 seconds...
    Writing...
    Operation took 0 minutes 7 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai5.91mc
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8493094DBDC68E8313285631F3
    MSID decoded: 3E4EBAE900D0BD66AA000000
    FAID: 2DE59EC7320975C56F5C9250
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Writing...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Flashing Done!
    Operation took 2 minutes 8 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    FAILED
    pác nào chỉ em cách sử lí với ạ.thank ạ !
    ĐÔ LƯƠNG _ NGHỆ AN
    làm lại ic nguồn rồi chạy lại bằng ver cao nhất nhé chúc thành công
    Thành viên chính thức coffee_mobile's Avatar
    Oct 2009
    chạy lại ver cao hơn đi anh ơi
    luôn luôn lằng nghe......lâu lâu mới hiểu
    Apr 2010
    chạy 5.91 rùi mà hix chạy = HWK thì nó kô UI đc,chạy = JAF thì nó UI đc nhưng vẫn kô lên.hix
    Apr 2010
    chạy = HKW sau khi đóng lại nguồn nè
    1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.1.0.0]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF
    Algorithm: u3_amd.fia, Ver: 4.79.0
    Algorithm Ok, MSID: 848561D0E29E74C5B01548E84C
    Decoded MSID: 3E4EBAE9-00D0BD66-A8000000
    Encoded FAID: 021FB3A8-D81D743B-B9AA56AB
    IMAGE: rh105_05.910
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
    Area2: 0x01010000-0x013AFFFF Erased, Time: 00:22
    Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:01
    Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
    Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:14
    IMAGE: rh1050_nai5.91mc
    Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01
    CNT Flashing Completed, Time: 00:01
    Extracting Contents Package ...
    Init Local Mode Failed
    Contents Package Extracting Failed:
    hix Pro nào chỉ em với (
    Jan 2009
    Kiểm tra BSI rồi chạy lại đi anh, em vừa làm nếu ko được thì thay UPP là ok
    Oct 2007
    Kiên Giang
    thay con cpu khác là vừa rồi. chúc thành công!
    Điếu thuốc tàn bên ly cafe cạn
    Đời khốn nạn khi em bỏ ra đi.
    Apr 2010
    hix thay kô biết bao nhiêu con rùi các pác ạ! cả U mới luôn nản quá phải trả thôi.
    Aug 2008
    => Chạy tới sang năm cũng chưa có lên nổi đâu
    Kiểm tra đường từ CPU qua Flash,thay Flash.
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
    Thành viên tích cực nguyentienthanh_dt's Avatar
    mod nói đúng đó làm chân đóng lại hoặc thay flash
    ****daithanh mobile****tienthanhfpt@hcm.fpt.vn ***
  1. 1209 mất nguồn
    By huuvinh29 in forum DCT4 - WD2
    Bài viết cuối: 15-10-2011, 23:54
  2. 1209 bỏ sim mất nguồn
    By sydungdtdd in forum DCT4 - WD2
    Bài viết cuối: 13-10-2011, 17:41
  3. 1209 mất nguồn
    By thuytrinh in forum DCT4 - WD2
    Bài viết cuối: 20-06-2011, 15:54
  4. 1209 mất nguồn
    By phalemo in forum DCT4 - WD2
    Bài viết cuối: 23-01-2011, 10:26
  5. 1209 hao nguồn động
    By phungvannghiempc in forum DCT4 - WD2
    Trả lời: 11
    Bài viết cuối: 20-05-2010, 15:34
