máy : bấm nguồn lên ok nhưng được khoảng 5s là trắng mh,dao dộng trên áp thì lên tới 1A mh xập nhưng dao dộng thì đứng im bấm fim ko thấy dao động ji nữa.ae jup với
cpu tơi 80% còn 20% là uem . dòng này cpu thay ko chối bạn thay cpu chạy lại đi. writer luôn pm good . thân .
ace nào có ver cao hơn cho e nhé,để e thử lại coi sao.trên support chỉ có mỗi ver đó thui ah
log của e nó đây ae xem dùm e cái.
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.40
12-01-07
RH-93
(c) NMP
HW version: 0526
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: WIN:MYKS:01
ST7506
PPM version: V 6.40
12-01-07
RH-93
(c) NMP
MD
ADSP SW version: V 6.40\n12-01-07\nRH-93\n(c) NMP\nmd
Production serial number: IDF369398
Product code: 0536561
Module code: 0203169
Basic production code: 0536354
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 357655015640675
IMEI spare to net: 3A 75 56 05 51 46 60 07
IMEI SV to net: 33 75 56 05 51 46 60 37 F5
Master Code: 0515343175
Phone type: RH-93, Software version: 6.40, Language Pack: MD
User code: :-(TUANHUN
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0536561
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_05.540
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_05.54md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai5.54md
Languages in ppm: English,Filipino,Vietnamase
Done!
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_05.540
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: bb
Loader is ready...
MSID: 84E122540C97D71F99214E8495
MSID decoded: 3E4EBAE9001E5E6AA8000000
FAID: 0C4B9C462443D107799A0A8A
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 36 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 17 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_05.54md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84D7E30CE109EE718E11608340
MSID decoded: 3E4EBAE9001E5E6AA9000000
FAID: 2C116855452B8FADADD7D1E0
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 14 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai5.54md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 2 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-93, Software version: 5.54
IMEI: 357655015640675
Resetting PPC...
Done!
Changing mode...
Done!
up..........................cho ace thấy để giúp e nè
wa skype HOANGLANH83 minh send cho mang lỗi ko up dc . thân
PHONG NGUYỄN (30-04-2010)
bùn wa ae ui,chạy ver 7.02 rùi mà vẫn chưa ok nữa
