các bác giúp tui với ,mình có con 1200 bị thợ làm hư cpu và ic nguồn mình đã thay rồi chạy lại chương trình xong mở nguồn ok nhưng ko read UEM được chỉ unckock được thôi nó báo thế này:
MCU SW version: V 5.53
07-08-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w21_U
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 5.53
07-08-08
RH-99
(c) NMP
MA
ADSP SW version: V 5.53\n07-08-08\nRH-99\n(c) NMP\nma
Production serial number: ING193918
Product code: 0546885
Module code: 0203402
Basic production code: 0544418
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 6F F4
Master Code: 5013663745
Failed reading simlock data...
Phone type: RH-99, Software version: 5.53, Language Pack: MA
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0546885
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.530
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.53mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.53mr
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Done!
Setting test mode...
Setting FULL FACTORY...
Failed! Aborting!
Resetting USER DATA...
Operation took 0 minutes 0 seconds...
Done!
Resetting LEAVE FACTORY...
Done!
Resetting SERVICE CENTER...
Done!
Resetting UPGRADE SOFTWARE...
Done!
Resetting PRODUCTION TUNE...
Done!
Done!
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
Booting phone...
Error booting phone...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
Flashing Done!
Operation took 0 minutes 15 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: ???????????????
Resetting PPC...
Done!
