Kết quả 1 tới 9 của 9
    Thành viên tích cực xecgayhiep's Avatar
    vĩnh phúc
    Mặc định 1200 chết nguồn
    1200 của em chạy pm như vậy nè.bấm nguồn dao động ngon lắm nhưng ko lên ạ. bác nào chỉ em zoi
    log đây ạ:
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.80
    14-11-08
    RH-99
    (c) NMP
    HW version: 1503
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: V 5.80
    14-11-08
    RH-99
    (c) NMP
    MR
    ADSP SW version: V 5.80\n14-11-08\nRH-99\n(c) NMP\nmr
    Production serial number: DFV958723
    Product code: 0546885
    Module code: 0203402
    Basic production code: 0544418
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 359553017063996
    IMEI spare to net: 3A 95 55 03 71 60 93 09
    IMEI SV to net: 33 95 55 03 71 60 93 69 F8
    Master Code: 5434006767
    Phone type: RH-99, Software version: 5.80, Language Pack: MR
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code: 0546885
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
    Checking path: \Products\RH-99\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.800
    Phone Type:
    PPM Flash file: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.80mr
    Phone Type:
    CNT Flash file: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh990_nai5.80mr
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.800
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x6822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: 50
    Loader is ready...
    MSID: 845B3812B78128E7438B8AF4B3
    MSID decoded: 3E4EBAE90019FD6AA9000000
    FAID: DDBD3FCEE5D2012927F8FCEB
    Operation took 0 minutes 12 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 0 minutes 24 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 14 seconds...
    Restarting MCU...
    PPM: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.80mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84381EE2789DADB898FBD7DF37
    MSID decoded: 3E4EBAE90019FD6AA8000000
    FAID: D6FDD42EF413E26350E7DFEF
    Operation took 0 minutes 13 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 7 seconds...
    Writing...
    Restarting MCU...
    CNT: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh990_nai5.80mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 840FDE5E6BE16AD6940CB361C9
    MSID decoded: 3E4EBAE90019FD6AAA000000
    FAID: 350A9754F82773525B997909
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Writing...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Flashing Done!
    Operation took 1 minutes 46 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    IMEI: 359553017063996
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Operation took 0 minutes 4 seconds...
    Done!
    Done!
    Unlocking...
    ASIC: b
    SW version: 5.80
    Selected flash file: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.800
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 02
    MCU ID: 0x2292
    Algo is ready...
    Erasing area: 011E0000 - 011FFFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 1
    Done!
    CƯỚP ĐƯỢC 1 Ổ BÁNH MỲ,BẠN SẼ VÀO TÙ. CƯỚP ĐƯỢC 1 GIANG SƠN BẠN SẼ LÀM VUA
    Jan 2009
    kiểm tra đường màn hình, check connect, cáp, tụ trở xung quanh connect là ok, ko phải đụng vào ic nào cả
    vĩnh phúc
    mọi thư đều bình thường mà.bác cho em ý kiến khác đi.bấm nguồn nó lên đẹp rồi đứng yên luôn.ko trở về 0.
    vĩnh phúc
    không bác nào giúp em à
    Jan 2009
    Chủ thớt thấy cái này có bình thường không? Đã chỉ cho rồi còn bảo ko ai giúp gì nữa
    Thành viên mới khanhquangmobile's Avatar
    Feb 2010
    bạn chạy không có màn hình nó không lên đâu, phải gắn màn hình vô mới được
    vĩnh phúc
    éc.lần trươc em chạy ko màn vẫn lên mà.hic
    Thành viên tích cực phu quy's Avatar
    Sep 2007
    thay cáp thay màn đi và xem lai mấy con trở ở gần connec xem có sao ko máy này ko có lỗi gi đâu hoặc là đứt hẳn đương BSI rồi
    QUÊ HƯƠNG HƯNG ĐẠO VƯƠNG
    Thành viên chính thức DungxMobile's Avatar
    Feb 2009
    Usa
    Màn hình hay không lắp sim vô biết liền
    https://t.me/pump_upp
  1. Trả lời: 5
    Bài viết cuối: 10-08-2013, 18:37
  2. 1200 chết nguồn
    By xecgayhiep in forum DCT4 - WD2
    Trả lời: 18
    Bài viết cuối: 08-07-2010, 20:15
  3. 1200 chạm nguồn
    By Thanhtuanmobile in forum DCT4 - WD2
    Bài viết cuối: 20-11-2009, 21:51
  4. Trả lời: 2
    Bài viết cuối: 21-04-2009, 09:25
  5. 1200 chết nguồn .
    By HEOSUA in forum DCT4 - WD2
    Bài viết cuối: 27-11-2008, 08:59
