Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-105\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91mr
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
Booting phone...
MCU ID: 0x2292
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x78C8; Loader chk: cc
Loader is ready...
MSID: 84A6F41E2F161741712F571930
MSID decoded: 3E4EBAE900D9DD77A8000000
FAID: DB76FC72CBC6C0FE82018E4D
Operation took 0 minutes 10 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 0 minutes 26 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 8 seconds...
Writing...
Operation took 0 minutes 7 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
MSID: 84466F3C2723FD4750533FFF43
MSID decoded: 3E4EBAE900D9DD77AA000000
FAID: E894D3E1A0079E4532A60C0B
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 36 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 5.91
IMEI: 352930028552471
Product Code:
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Powering the phone...
Unlocking...
ASIC: b
SW version: 5.91
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 01
MCU ID: 0x2292
Algo is ready...
Erasing area: 01160000 - 0117FFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
MCU ID: 0x2292
Algo is ready...
Done!
DCT4 unlock counter: 14
Done!
e chạy xong nó báo contact service là sao vậy các huynh. thanks các huynh trước
