máy đã xóa full và flash + wriet pm backup rpl + sim lok nhưng chỉ chạy được 1 phút là tắt máy đây là log phone info
Version Info:
MCU SW version: V 3.03 26-10-06 RH-97 (c) Nokia.
HW version: 4053
UEM version: 1328
UPP version: 12352
RFIC version: 0500
DSP version: P05w19.v31
LCD version: SUEZ
PPM version: V 3.03 26-10-06 RH-97_98 (c) Nokia. V
Product Info:
Production serial number: PHI482334
Product code: 0531292
Module code: 0202895
Basic production code: 0530102
ATO: p?????????????????????????????????????????????????
Serial Numbers:
IMEI plain: 354546011418153
IMEI spare to net: 3A 45 45 06 11 14 18 05
IMEI SV to net: 33 45 45 06 11 14 18 05 F4
Other Info:
Model : Nokia 6060 (Classic Phone)
CS type : GSM900/GSM1800/GSM1900
BSI: 2.0 KOhm
Imei net: 35454601141815
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
log bus check
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x3040 [UPP_4M ver: 4.1]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
UEM ID: 00505B34: DA3BDA66
ASIC type: 11
UEM Imei: 35454601141815
Phone Type: RH-97 (Nokia 6060)
SW Version: V 3.03 26-10-06 RH-97 (c) Nokia.
Imei plain: 35454601141815-3
Product Code: 0531292
Cellular System: GSM
ASIC ID: 0x3040, type: 11
Ppm Id: V
Language Pack:
- not available.
Counter: 0/3, 0/10
anh em xem có lỗi chỗ nào chỉ dùm với !
