bỏ vào mtkey sửa lổi là hết à bạn ơi
anh em sem dúp em
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-64
(c) NMP
HW version: 0526
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 7.02
10-12-07
RH-64
(c) NMP
MD
ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\nmd
Production serial number: IFE116664
Product code: 0536461
Module code: 0203169
Basic production code: 0536354
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356068035085957
IMEI spare to net: 3A 65 60 08 53 80 95 05
IMEI SV to net: 33 65 60 08 53 80 95 45 F5
Master Code: 1556663413
Phone type: RH-64, Software version: 7.02, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini
Setting local mode...
Reading product code...
Product Code: 0536461
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\
Checking path: \Products\RH-64\
No ini files found...
Done!
Phone Type:
MCU Flash file: F:\THAIBINHMOBILE\NOKIA\FLASH FILE\DCT-4 & WD2\1110i_1112 RH-93\7.02\rh93_07.020
Phone Type:
PPM Flash file: F:\THAIBINHMOBILE\NOKIA\FLASH FILE\DCT-4 & WD2\1110i_1112 RH-93\7.02\rh93_07.02md
Phone Type:
CNT Flash file: F:\THAIBINHMOBILE\NOKIA\FLASH FILE\DCT-4 & WD2\1110i_1112 RH-93\7.02\rh930_nai7.02md
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: F:\THAIBINHMOBILE\NOKIA\FLASH FILE\DCT-4 & WD2\1110i_1112 RH-93\7.02\rh93_07.020
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader version: 04.50.00 -> Revision: 0007
Loader size is 0x5718; Loader chk: 31
Loader is ready...
MSID: 84FEA14F5664E6EA375FAD0B78
MSID decoded: 3E4EBAE900450D42AA000000
FAID: 9C378ACDC5DD032FD71B7F5A
Operation took 0 minutes 7 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 35 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 16 seconds...
Restarting MCU...
PPM: F:\THAIBINHMOBILE\NOKIA\FLASH FILE\DCT-4 & WD2\1110i_1112 RH-93\7.02\rh93_07.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 8 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 14 seconds...
Writing...
Operation took 0 minutes 13 seconds...
Restarting MCU...
CNT: F:\THAIBINHMOBILE\NOKIA\FLASH FILE\DCT-4 & WD2\1110i_1112 RH-93\7.02\rh930_nai7.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09D8
Boot is ready...
Loader is ready...
MSID: 843B3CAD08D11D5F68D7FAA84D
MSID decoded: 3E4EBAE900450D42A8000000
FAID: A97644E786FD442DF99CD8D8
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 54 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-93, Software version: 7.02
IMEI: 356068035085957
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Done!
mang qua M-XKEY sửa lỗi này ok liền , nếu ở gần mình mang qua đay mình làm cho
check ngư thế nào bạn quang cái log lên ace coi thì mới giúp được chứ khả năng là đóng chưa chuẩn hoặc CPU lỗi
em đã chek đây
MCU ID: 0x2201
Algo is ready...
Done!
Phone Restarted...
kiếm con u good thay vào đi anh
99% bị chân conec bạn thay cái này chắc OK
