a mua cáp ốp lung bao nhiêu vậy
cái này chủ yếu bị lỗi cứng thôi anh
nhan_chim (28-10-2010)
em củng vậy mấy huynh ơi.cáp đa năng chạy kg được
CÁC BẠN LÀ THẦY CỦA TÔI
em dùng cáp đa năng cũng vậy.thôi để ae nào làm rôi post lên cũng được.chuối quá
đây bạn tham khảo còn đây là log check
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
Device synchronized.
CPU ID: A200341100 [X-GOLD 110]
Sending Primary Boot Loader ...OK
Changing baudrate to: 921600
Sending Secondary Boot Loader ...OK
BootloaderString: SE0_091125 F11
Boot mode: CC
EBL version: 10.13, Default_RAM_Bootloader
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Phone Type: RM-647
SW Version: V 04.20 07-05-10 RM-647 (c) Nokia
Imei plain: 35431104906452-3
Product Code: 0592248
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35431104906452
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
còn đay là log flash
Do not disconnect or abort this operation otherwise phone will be damaged.
Boot mode: CC
Processing CODE:hw_b2_rm647_r03.600.fls from file rm647_003.600
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming ...
Programming completed in 32.172 s
Erasing area 0x00C60000-0x00EAFFFE ...OK
Programming ...
Programming completed in 30.844 s
Erasing area 0x00FFC000-0x00FFFFFE ...OK
Programming ...
Programming completed in 0.047 s
Checksum failed
Processing CUST:hw_b2_rm647_003.60mr.fls from file rm647_003.60mr
Erasing area 0x00210000-0x0045FFFE ...OK
Programming ...
Programming completed in 15.250 s
Checksum failed
Processing CUST:hw_b2_rm6470_nai03.60mr.fls from file rm6470_nai03.60mr
Erasing area 0x00EB0000-0x00F7FFFE ...OK
Programming ...
Programming completed in 4.218 s
Checksum failed
Flashing completed in 3 min 8.813 s
Phone Type: RM-647
SW Version: V 03.60 01-04-10 RM-647 (c) Nokia
Ppm Id: MR
Language Pack:
- not available.
Version:
Counter: 0/3, 0/10
mxkey flash 1280,1616 ok nếu có cáp ôp lung càng tốt còn không dùng cáp đa năng dct4g (pinnua) như 1202 trước khi check tối thiểu bạn phải tích vào X-GOLD và chọn đc file mcu
nhưng chua support unlock
em chạy được rồi,mà vẫn hok hết bệnh,cũng nghĩ là phần cứng mà đã làm hết rồi nên flash thử,cái 1280 vệ sinh cũng chết míc
po tay.rút kinh nghiệm lân sau,cám ơn ae đã quan tâm
múc bằng cáp đa năng.pin out giống 1202.phải chạy bằng mx-key mới dc
bac nao chay roi xin giup em voi
Chú ý : Sử dụng tiếng Việt có dấu và không Spam bài cũ
e chao cac bac em moi vao nghe vua hom qua nhan mot con 1280 vao phan xap xep thi may sap nguon khoi dong lai may.bac nao chay roi thi chi giao cho em vai chieu voi e dang dung jap va phoenix e xin cac bac giup do. xin cam on cac bac![]()
