có mxkey cũng không ăn thua dâu,thay u chạy lại và unlock 100% ok
MINH-CHÂU ( Krông Năng-Đăk Lăk ) ĐT:0985.012747
mình chạy JAF log của nó đây
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.00
14-11-08
RH-112
(c) NMP
HW version: 1000
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_08w31_UPP
LCD version: WIN:SERI:8a
NT7542
PPM version: V 03.00
14-11-08
RH-112
(c) NMP
MR
ADSP SW version: no NAI version
Production serial number: HBC399674
Product code: 0562273
Module code: 0203762
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352902027372623
IMEI spare to net: 3A 25 09 02 72 73 62 02
IMEI SV to net: 33 25 09 02 72 73 62 12 F4
Master Code: 5117463245
Failed reading simlock data...
Phone type: RH-112, Software version: 03.00, Language Pack: MR
User code: #
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code: 0562273
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
mình unloc bằng bản này
UFS Box Version: 00
UFS Box SN: 0
Powering the phone ...
Please Wait...
Reading phone info ...
Type: RH-112
Version: V_03.00_14-11-08_RH-112_(c)_NMP
ASIC Type: 11
IMEI: 352902027372623
UPP version: 8851
Production SN: HBC399674
HW Signature: F301819867D3F91D
Simlock Key: 0000000000000000
Simlock Profile: 0000000000030000
Simlock Aux: 000B0000
SP LOCK status:
Cable counter: 0/10
Key counter : 0/3
Read Phone Info OK
Your request is waiting for calculation. Estimated time (hh:mm:ss): 03:14:56
bạn ko có MX key thì đừng mong unlock con này nhé. bằng tool free unlock dct4 thì ko được đâu.
con này nếu có mx unlock 1 phát là ok. vẫn chưa unlock đượcSimlock Key: 0000000000000000
mobile services
NHƯ HẠ
yahoo: gialai_gsm
qua kho 123 (31-10-2010)
bạn thư gơ bỏ con tụ trên đường PSI gần chân pin và con kiểng 4 chân gần UEM đi bạn.nếu hên thì ok
lỗi này có cách gì khắc phục đc kg vì ở chổ minhf kg có nhìu thợ kg có ai làm pm , dòng này từ trước tới giờ mình vẫn unloc dc ,bạn phán cho mình xem lỗi do máy hay do cài bõc -minh mói cài lại win
tóm lại chỉ có cái box đó thì không thể làm ok con này anh nhé
muốn ok thì thay cpu 1200 vào rồi làm lại là ok
bạn vệ xin lại ổ cáp xem sao kh được bỏ vào mxkey unlock là ok liền
