MG160 / KG 275 dead and cannot be booted after flash with wrong file.
Solution to repair.
1. Please use fully charged battery.
2. Run Proper module ( Currently LG KE Module v. 1.0.0.2013 )
3. Deattach battery from phone , phone must be not connected to cable.
4. In sw Module choose proper com port, "write flash" job, and file MG160bP16FL-55-V10a-724-05-MAR-19-2007+1.bin from support.
5. Press "Do Job".
6. When the message " Press power On" appeared in window - Connect phone to cable and Only NOW insert battery. Flashing should start.
7. After job done, you can read codes from it , or flash any other proper flash file from support.
Important! Solution is tested and work only for phones killed by wrong file flashed using Furious sw. We do not have any idea if it may work for phones killed using any other sw. !
