FuriousTeam Santa clause bring you GOLD as 1st in world updates
Par STEVE ADMIN, Sunday 23 December 2007 à 09:25 :: New Updates
QFG MODULE NEWS:
[X] TU720/CU720 FULL FLASH/NVM READ/NVM WRITE
[X] FOMA L600i FULL FLASH/NVM READ/NVM WRITE/IMEI CHANGE
[X] KU990 VIEWTY/U990 FULL FLASH/NVM READ/NVM WRITE
[X] ON FLY PATCH (PATCH FW WHILE FLASHING FOR UNLOCK)
[X] U8500, KU730, TU500, TU500F, TU550, MU500, CU500, CU500V, CU400, CU405
UNLOCK VIA "ON FLY PATCH" OPTION
[X] 5GB WITH LATEST FIRMWARES (WE STILL HAVE BIGGEST DATABASE FOR LG FLASHES !!!)
NOTE : REQUIRES PACK 1 AND FW 1.65
SIEMENS MODULE (NEW ADDON BY LAZY CODER):
Wors Without Test Point
[X} SUPPORTED MODELS:
C65, CX65, M65, S65, SK65, SL65, SP65, C70, CX70, C72, C75, CF75, CX75, M75, ME75, M77 (SGold ), S75, SL75 (SGold2)
• Unlock
• Change IMEI
• Backup/Restore
• SKey calculation
[X] FEATURES:
Skip service mode – used if BFC-bus already opened, or bootcore patched, or Test-Point used. Else, if bus not opened, used some trick to erase bootcore. Than phone accept any loader.
Calculate SKey – Skey calculation using EEFULL block 5121. Calculated SKey stored in Siemens.ini file for future use. Calculation took about 2-5 minutes.
Unlock - Clear all phone locks.
Fix bootcore – fix formatted/damaged bootcore.
Disable OTP check – firmware patch disable checking OTP IMEI. Need for change IMEI.
Change IMEI – Change phone IMEI except OTP part. For correct work need Disable OTP check option used.
Flash areas – select areas for backup/restore than press Read flash (for backup) or Write flash ( for restore).
NOTE : REQUIRES PACK 3 AND FW 1.65
