Trang 9 của 10 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 CuốiCuối
Kết quả 81 tới 90 của 92
    V.I.P minhphuc's Avatar
    Apr 2006
    unlock ok zte 431
    Software engine version: 1.0.0.8530
    Searching phone ...
    MODEL : QCOM SERIES 26
    COMPILED DATE : May 25 2012 17:27:00
    RELEASE DATE : Feb 2 2012 18:00:00
    FIRMWARE INFO : ATT_AM_P671A90V1.0.0B17-S
    IMEI : 86183100182996-5
    BLUETOOTH ADDR : 09 EA BC CF E0 34
    INIT NAND ROUTINES;
    NAND INIT MADE;
    PHONE CODE: 0000
    READING;
    CALCULATING;
    BEFORE BACKUP: 5EF8510C19F96000413C001DFDB7B60C.bin
    ERASING;
    WRITING;
    READING;
    AFTER BACKUP: 03538C0FFDD8406E9CFD6BB47D9C1831.bin
    UNLOCKED;
    RESET !
    Time needed - 00:00:11
    Thành viên chính thức tridongthap75's Avatar
    Nov 2006
    Châu Đốc - An Giang
    TOSHIBA TG01 Read code ok
    Apr 2006
    zte t50 unlock ok
    Searching phone ...
    MODEL : QCOM SERIES 10
    COMPILED DATE : Aug 25 2011 20:48:00
    RELEASE DATE : Jun 3 2010 07:00:00
    FIRMWARE INFO : TEL_AU_P671A70V1.0.1B03-S
    IMEI : 86824600084353-2
    BLUETOOTH ADDR : 8B 5E 6C 5B 7B C8
    INIT NAND ROUTINES;
    NAND INIT MADE;
    PHONE CODE: 0000
    LOOKING SENSITIVE DATA;
    DATA FOUND;
    SP NEW DETECTED;
    READING FW SIGN;
    READING NET DATA;
    READING NCK DATA;
    READING PUBLIC KEY;
    CHECKING SIGN;
    SIGN OK;
    LOCKED NET 1 (MCC: 1 MNC: 1)
    READING;
    CALCULATING;
    ERASING;
    WRITING;
    UNLOCKED;
    RESET !
    Time needed - 00:00:09
    V.I.P livemobi's Avatar
    Jun 2011
    chia sẽ 1 e
    Unlock ZTE V768 OK
    cài driver xong tắt máy => read code => kết nối USB => xong
    Attach the phone to the USB now ...
    Phone found on COM57 and initialized;
    Reading imei;
    IMEI: 865074-01-021734-6
    Reading data;
    Log saved: 070814C02094C961C8C986331FC50CCC.bin
    Enter an restricted sim and use as unlock code : 00000000 (8 times 0)
    NOTE: For ZTE models enter *983*258# in order to be able to input code
    SIM_LOCK REMOVED !
    Resetting the target ...
    Time needed - 00:00:17
    CHUYÊN Unlock Mở mạng - Nạp TV - Repair boot all Mobile
    Tel: (08) 22.102.872 - Mobile:
    0907 225 175 (Mr HUY)
    Hỗ trợ Y!H: livemobi
    Apr 2006
    moi support con âctel ot871a đem ra unlock thử thấy ok
    Searching phone;
    Phone detected (MTK USB Port)
    Preparing to start meta mode;
    COM opened ok;
    Phone must be poewered off;
    Keep presing the button !
    (for USB connection keep space key pressed and insert the usb cable)
    Connecting;
    Meta mode entered;
    Baseband Chip: MT6276
    Sw version: MAUI.11A.W11.12.SP1.V8.F10
    Hw Version: JRD76_11A_GEMINI_HW
    Reading phone info;
    IMEI: 013160-00-181177-4
    Reading simlock info;
    Unlock codes:
    network_key: 0057448906
    network_subset_key: 1466912690
    service_provider_key: 2752545588
    sim_key: 1751566635
    Jun 2011
    Unlock ZTE T12 ok
    Searching phone;
    Phone detected (MediaTek PreLoader USB VCOM (Android))
    Searching for debug port; (be sure drivers from support were installed)
    Debug Port found on ZTE NMEA Device (COM58);
    Preparing to connect meta mode;
    Meta mode entered;
    Baseband Chip: MT6573, E00
    Sw version: MAUI.11AMD.W11.37.SP.V3.F1
    Hw Version: ZTENJ73_HW
    Reading phone info;
    IMEI: 862031-01-022981-5
    Locked to: 505-01
    code_cat_n: 12345678 enabled: yes tries: 10
    code_cat_ns: 56781234 enabled: no tries: 10
    code_cat_sp: 11112222 enabled: no tries: 10
    code_cat_c: 33334444 enabled: no tries: 10
    code_cat_sim: 65656666 enabled: no tries: 10
    code_cat_ns_sp: 77778888 enabled: no tries: 10
    code_cat_sim_c: 99990000 enabled: no tries: 10
    Time needed - 00:01:48
    Nov 2006
    Châu Đốc - An Giang
    ZTE F256 unlock code ok
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Unlock OT-871A DONE.
    Searching phone;
    COM opened ok;
    Phone must be powered off;
    Keep pressing the power button if serial used !
    (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable)
    Connecting;
    Meta mode entered;
    Reading phone info;
    IMEI: 013160-00-127471-8
    Unlock codes:
    network_key: 1165674854
    network_subset_key: 0212550383
    service_provider_key: 0094364111
    sim_key: 0755766947
    If the counter is blocked or the phone is not asking for codes, insert and accepted sim and type ###765*08#;
    Time needed - 00:00:18
    Mar 2008
    Đến từ Huế city.
    Unlock ZTE Z431 OK
    Software engine version: 1.0.0.8682
    Searching phone ...
    IMEI : 86183100131037-0
    BLUETOOTH ADDR : 7F FC BD CF E0 34
    INIT NAND ROUTINES;
    NAND INIT MADE;
    PHONE CODE: 0000
    READING;
    CALCULATING;
    ERASING;
    WRITING;
    READING;
    UNLOCKED;
    RESET !
    Nov 2006
    Châu Đốc - An Giang
    VIETTEL V8403 unlock ok
  1. Trả lời: 86
    Bài viết cuối: 24-07-2016, 23:49
  2. Trả lời: 43
    Bài viết cuối: 07-08-2014, 09:15
  3. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  4. Trả lời: 1
    Bài viết cuối: 27-05-2011, 10:46
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 20:26
