Hi !
Due the lack of space on some dongles we were forced to created a new maintainance with the ability to update parts of the applets required by our modules to run. That was done in this version.
NOW YOU HAVE 3 UPDATE OPTIONS:
[X] MODULES PACK 1 - IF YOU INTEND TO USE NEC M2 - 'READ CODE' FOR NEW NECS OR TREO MODULE - 'TXT TO CODE' FEATURE.
[X] MODULES PACK 2 - IF YOU PLAN TO USE ALL MODULES EXCLUDING ONES MENTIONED IN PACK 1
[X] ALL MODULES - IF YOU PLAN TO YOU ALL MODULES EVER BUILT FOR FG (THIS WILL COMPLETE SUCCESFULLY FOR MOST OF THE DONGLES BUT ONE SOME NOT DUE THE LACK OF SPACE)
HOW TO USE:
1. FORMAT YOU DONGLES
2. SELECT APPROPIATE UPDATE YOU NEED (PACK1, PACK2, ALL)
3. UPDATE DONGLE
4. THIS OPERATION CAN BE REPEATED EACH TIME DEPENDING SOFTS YOU NEED TO USE.
IN THE END I WOULD LIKE TO SAY SORRY TO ONES HAVING SMALL MEMORY DONGLES FOR ANY INCONVENIENCES.
NEW MAINTAINANCE CAN BE FOUND UNDER BETA FOLDER OF SUPPORT.
