Remote Tools:
V 1.0.0.24 - 18 Jan 2009
- Support for SL3 data requests and status check. No
more need for separate executable for Beta testing
of SL3 Unlock, all is activated based on the user
server privileges
- User Name and Password boxes moved to the About menu.
The login credentials will be saved to the ini file
regardless if use server check box is selected
- New loaders added for not supported RAPIDO hashes
Now will be possible to unlock E63 v200 via RPL file (thanks
to James for the test phone !)
- No more need for good quality cable with RX2 connection
this should increase the comm stability with the cables in
mass use
- Super Dongle data added to calculated RPL file
- No more need to have 200 credits for the code reading
function
Nk4c.exe - the standalone DCT4/DCT4+ calculator for Genie:
V 0.0.0.18 - 18 Jan 2009
- No more need for standalone credits in the device to
calculate files
Genie OS:
v 0.0.0.183 - 18.01.2010
- Support for latest version of RemoteTools
- It is no longer possible to run plain Pawn
scripts. Please if you use your Genie to code
custom Pawn scripts - do not update to this version
NSS server version 0.114:
- No need to have 200 credits in the account to read unlock codes from
BB5 phones (PA_SL, PA_SL2)
- Reading of codes on all models except PA_SL3 is free (incl hash 9DDB...)
- Generating RPL file with simlock data + super dongle data cost 8 credits
on all BB5 models(incl hash 9DDB...)
To use this update please folow this procedure:
1. Update your SD card contents from the FTP
2. Update your device to 0.183( please check history.txt first !!!)
3. Download updated executable from the provided link
