Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 22
    Dec 2009
    GIALAI
    Mặc định HWK Update news
    This is the information that I have from Saras about the next update, this list is not final and more could be added before the release is ready, please do not ask when this will be released since I have no info on a release date:-
    DCTxBB5
    1. BB5 products: RM-576,RM-577 (6700s,6700s-1c) added.
    2. Local RPL Service Fixed for ASIC 2,5,6,7,11 (UEM_PASW is Correct now)
    Note: Need Confirm [Readout and Use UEM IMEI] when do [Rd UEM].
    3. [Check Ask/Rpl] Renamed to [Calc Ask/Rpl] as can Calculate RPL now.
    4. [Calc Ask/Rpl] Function will Generate Real RPL from ASK file (ASIC 2,5,6,7,11)
    Note: When Reading UEM, do not Forget Set Right [UEM Changed] Status !
    5. RSA Lock/Unlock for All DCT4+ products (not need Patch)
    6. Life Timer added to [PM Edit]
    7. DCT4 INFINEON Based Products USB Flashing / UI support added:
    RH-111,RH-125,RH-126,RM-607,RM-608,RM-643,RM-644,RM-647,RM-653,
    RM-669,RM-689,RM-704,RM-732,RM-733 (1202,1616-2,1616-2b,C1-01,C1-01.1,
    C1-02,C1-02.1,1280,1800,1800b,C1-00,C2-00,X1-00,X1-00.1)
    8. BB5 RAP3Gv40 Based Products USB Flashing / UI support added:
    RM-509,RM-510,RM-511,RM-540,RM-598,RM-604,RM-615,RM-638,RM-721,RM-722
    (3710a-1,3710a-1c,3711a-1,X3-00,7230-1c,7230-1,5330-1d,6303ci,C2-01,C2-01.5)
    9. BB5 RAPU Based Products USB Flashing / UI support added:
    RM-582,RM-596,RM-601,RM-609,RM-610,RM-627,RM-629,RM-632,RM-634,
    RM-639,RM-640,RM-645,RM-648,RM-658,RM-659,RM-662,RM-675,RM-682,
    RM-688,RM-691,RM-697,RM-699,RM-707,RM-718,RM-719,RM-720,RM-749
    (Vertu CQ,N8-00,C6-01,E6-00,E6-00.1,X5-01,5230-1d,E5-00,E5-00.2,X3-02,C3-01,
    C5-00.X5-01.2,E73,X7-00.1,C3-01m,C7-00,6702s,C5-00.1,C7-00b,C5-03,E5-00m,
    X7-00,C6-01.3,C5-03.2,C5-04.1,C7-00s)
    10.BB5 RAPIDO Based Products USB Flashing / UI support added:
    RM-484,RM-485,RM-486,RM-551,RM-552,RM-559,RM-588,RM-593,RM-594,
    RM-612,RM-624,RM-625,RM-684
    (N86-1,N86-3,N86-5,X6-00.1,X6-00m,X6-00,5230-1,5230-1c,5230-1b,C6-00,
    C6-00.1,5288,5250)
    11.BB5 JUNO (BCM21351) Based Products USB Flashing / UI support added:
    RM-497,RM-586,RM-614,RM-618,RM-709,RM717
    (7020a-2,2710c-2,C3-00,X2-00,X2-01,X2-01.1)
    LG_GSM
    1. Infineon:
    A110,A130,A133,A133GO,C100,C105,C300,C300GO,C305,C 310,GB220,
    GB220nGO,GB230,GB280,GD350,GD510,GD510N,GM360,GM36 0i,GM600,
    GS170,GS290,GS290GO,GS290N,GS390GO,GS500,GS500g,GS 500gx,GS500v,
    GT350,GT350GO,GT350i,GT360,GT365,GU220,GU230,KF510 ,KF510d,
    KM380,KM380c,KM380d,KM385d,KM386c,KP500,KP500N,KP5 01,KP502,
    KP502GO,KP505,KP550,KP570q,KS360,KS365,T300,T310,T 310i,T310N,
    T315,T315i,T320,T320e,T320g,T325 added.
    Notes:
    1. To See Unlock Codes and Instructions, Press [BOOT]
    2. To Flash Dead Phones, Tick [Emerg. Boot]
    2. MTK A120,A155,A160,A165,GB161 added.
    3. BT Address Write Added for Infineon and MTK platforms.
    SAMs
    TRIDENT
    A127,i626,X475 added (DUNL,IM,FL)
    OM(SYSOL)
    T209,T319 added (DUNL,IM,FL,SECT)
    SWIFT
    A436,A437 added (DUNL,IM,SECT)
    Note: For Flashing use A4xxxx_RD files.
    A516,A517,T229,T249,T339,T349-LTA-USA,T369,T409,T619,T739
    added (DUNL,IM,SECT,FL)
    Added Multi Drive support for TFS Read.
    SWIFT-AEROFONE
    Added [Patch MSL] Function to Patch without MCU Part Flashing.
    T109,T119 added (DUNL,IM,FL)
    E1080F-IND-MEA-SEA,E1081T-EU-IND-MEA-SEA,E1085F,E1085F-MEA,
    E1105F,E1150i,E1160i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F,
    E1225T,E1225T-IND added (PUNL,PIM,FL)
    Notes:
    1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets.
    2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA.
    3.For Cross Flashing Select Model Name Extension by File type.
    4.Before Unlock, Info to see Codes or Rebuild IMEI use
    [Patch MSL] Button or Flash with [Patch MSL] Option Enabled.
    C3222 added (DUNL,CUNL)
    Note: C3222 Flashing not Supported yet, use Original Flasher.
    SWIFT-3G
    C5010E,E3210 added (CUNL,SECT,FL)
    QUALCOMM
    A847,A927,B2710D,C5180,S5520,S5580,S6700T,S6888,T3 59,T479,T749 added.
    More Versions Support of Hidden Sysinfo models CUNL and UNFR:
    A706,A707,A717,A727,A847,A887,A897,A927,B2710,B271 0D,S3370,
    S5530,T359,T469,T479,T559,T659,T749
    QUALCOMM+LSI
    S8500B,S8530 added (FL)
    BROADCOM
    S5230N added (FL,CUNL,UNFR,BRP)
    S5330L,S5750E,S5753E,S7230E,S7233E added (FL)
    S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP)
    INFINEON
    B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2530,S331 0i,S3350,
    S3353,S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL)
    E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000)
    Regards,
    Odia.
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  2. ( GIALAI_GSM ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
    DuyQNgãi (18-05-2011), QUANGTRUNG_GSM (18-05-2011), silly (18-05-2011)
    Đất Hà Thành!
    tin hot nè!
    May 2010
    ĐIỆN BIÊN
    hay quá ko biết bản mới này làm việc thế nào nhẩy ae
    TRUNG HIẾU MOBILE
    Moderator DuyQNgãi's Avatar
    Quảng Ngãi City
    chắc là ko cần cầu hình khủng rồi
    Có thấy nói gì đến SL3 đâu mà ko cần PC khủng
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
    Thành viên chính thức hau2305's Avatar
    Jul 2006
    sao không thấy liên down gì cả vậy???
  8. #7
    V.I.P minh thai's Avatar
    Hic đến nay mới chịu update . nhưng dù sao củng an ủi phần nào .
    Bến Lức_Long An
    minhthai379
  9. #8
    V.I.P ThanhHai_GSM's Avatar
    Trích Được post bởi hau2305 Xem bài viết
    thông tin hwk chuẩn bị update thôi
  10. #9
    Dec 2009
    GIALAI
    đây chỉ là thông tin từ hwk chuẩn bị update. chứ chưa up
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  11. #10
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    có hỗ trợ usb nữa thì phải
  1. Universalbox news and update, check here!
    By taihv™ in forum Universal Box
    Trả lời: 48
    Bài viết cuối: 05-07-2012, 13:32
  2. MSS Box II News and Update
    By taihv™ in forum MSS Box II
    Trả lời: 35
    Bài viết cuối: 13-12-2010, 21:20
  3. Universalbox news and update
    By hungphongmobile™ in forum Universal Box
    Bài viết cuối: 01-08-2009, 23:15
  4. UBL news and update, check here!
    By taihv™ in forum Ultimabox Light
    Trả lời: 11
    Bài viết cuối: 02-10-2007, 08:20
  5. 19-Jan-2007, Infinity news and update!
    By taihv™ in forum Infinity Box
    Bài viết cuối: 19-01-2007, 10:11
