Trang 3 của 4 Đầu tiênĐầu tiên 1 2 3 4 CuốiCuối
Kết quả 21 tới 30 của 32
    Technical Assistance GIALAI_GSM's Avatar
    Dec 2009
    GIALAI
    repair bad softwaze ZT 898 ok
    PHP Code:
    COM14 [VCP0selected
    module  v3.23
    Device
    Autodetect 6205-6239 NOR
    Checking data
    wait...
    advanced flash detection enabled
    Action
    repair "Bad software"
    modemode-1
    ====>  Boot ...
    Press and HOLD Power button now !
    19200 fixed
    Connecting
    wait...
    Initializing [6225:8A03:8A00]...
    CPUMT6225
    high speed boot On
    chip
    0001:6E03:000D
    status
    FF
    boot packet size
    0400
    Release Power button now
    Boot Done
    ====>  Initialize ...
    detecting chip #00 in region #00...
    flashEC257E25082501:18E59F00000000
    flash
    Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x00200016Mb
    otp offset
    00000000
    detecting chip
    #01 in region #00...
    flash
    otp offset
    00000000
    detecting chip
    #02 in region #00...
    flash
    otp offset
    00000000
    detecting chip
    #03 in region #00...
    flash
    otp offset
    00000000
    number of flash chip
    /regions detected04/01
    Initialize Done
    ====>  Set baud ...
    921600
    Set baud Done
    ====>  Initialize bootcode ...
    Initialize bootcode Done
    ====>  Check firmware integrity ...
    device parameters detection in progress...
    flash
    otp offset
    00000000
    detecting chip
    flash
    otp offset
    00000000
    it
    's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
    number of flash chip/regions detected: 01/01
    total flash region size: 01000000
    usb bootloader detect...
    usb bootloader detect (phase #2)...
    usb bootloader (chip) is absent
    searching rom info...
    search rom info finished
    rom info structure: [protected] type (04), 1 record(s)
    TCL-ID is absent
    startup code area #1 is Ok
    startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.48758C85.[TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_32_MP_V7_M530.BIN_FA0130FF].rpl
    rom info detection finished
    device-id: 48758C85
    rom info ver: 04
    sw version: TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_32_MP_V7_M530.BIN
    project-id: MAUI.07A.W07.32.MP.V7_M530, FF3001FA
    code offset: 00000000
    ffs offset/size [01]: 00E00000/00200000
    TCL-ID is absent
    sec info (detailed) detection...
    searching sec info#1...
    search sec info#1 finished
    Check firmware integrity Done
    ====>  Check firmware content ...
    detecting licence parameter...
    detecting licence parameter name...
    phase #1...
    phase #2...
    done
    error: licence parameter name is not found
    What to do:
    1. Be sure that your phone really has "Bad software" problem, in other case DO NOT use "Repair "Bad Software"" button !
    2. Repeat "Repair "Bad Software"" operation several times to avoid communication problems.
    3. Flash phone with firmware from support area and repeat "Repair "Bad Software"" operation.
    If still no luck:
    1. read full flash and send to support: mt62xx@gmail.com
    2. send "operation.log" file to support: mt62xx@gmail.com
    file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_32_MP_V7_M530__system_log_48758C85_FA0130FF_20101212-202527.B0X.bin
    Finished, time used: 1 min 9 sec
    Remove/Install battery now !
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  2. ( GIALAI_GSM ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    MT BOX (29-06-2011), taduyduc (12-12-2010)
    Dec 2009
    GIALAI
    unlock Huawei-T201 ok
    PHP Code:
    COM11 [VCP0selected
    module  v1.73
    Device
    Huawei-T201-HW-A
    Checking data
    wait...
    Action"sp-unlock"
    unlock method-1
    Boot
    e-gold820000
    loading
    next part...
    boot answer01
    Boot Done
    Set Baud
    921600
    Set Baud Done
    Connecting
    flash007F:22F6
    Connecting Done
    Check hardware
    Check hardware Done
    Check parameters
    Check parameters Done
    backup critical area
    reading eeprom-static...
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-static_20101214-154155.B1E.bin
    loading data
    data loaded
    reading eeprom
    -security...
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-security_20101214-154155.B1E.bin
    reading eeprom
    -complete...
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-complete_20101214-154156.B1E.bin
    reading additional data
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_lock-area_20101214-154159.B1E.bin
    backup critical area Done
    Check memory
    lock found
    lock type
    #1 found
    Check memory Done
    Write
    Erasinglock-area
    Writing
    lock-area
    Write Done
    Finished
    time used23 sec
    Remove
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  4. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  5. #3
    Dec 2009
    GIALAI
    unlock Huawei T156 ok
    PHP Code:
    COM3 [VCP0selected
    module v1.78
    Device
    Huawei-T156
    Checking data
    wait...
    Action"sp-unlock"
    unlock method-1
    Boot
    e-gold820000
    loading
    next part...
    boot answer01
    Boot Done
    Set Baud
    115200
    Set Baud Done
    Connecting
    flash0001:22C4
    Connecting Done
    Check hardware
    Check hardware Done
    Check parameters
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20100925-165933.B1E.bin
    loading data
    data loaded
    reading eeprom
    -security...
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20100925-165934.B1E.bin
    reading eeprom
    -complete...
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20100925-165940.B1E.bin
    file savedC:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20100925-165959.B1E.bin
    Check memory
    lock found
    lock type
    #1 found
    Check memory Done
    Write
    Erasinglock-area
    Writing
    lock-area
    Write Done
    Finished
    time used1 min 7 sec
    Remove
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  6. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  7. #4
    Dec 2009
    GIALAI
    unlock LG KG130 ok
    PHP Code:
    com3 [vcp1selected
    module v1.39
    device
    Lg-kg130
    checking data
    wait...
    Advanced flash detection enabled
    action
    Reset
    boot
    Phone should be switched off !
    Press and hold power button now !
    Connectingwait...
    Release power button now !
    Flash01227e22212200:feea0000000000
    flash
    Amd amd/fujitsu std [d 0004x010000 003ex040000 0004x01000016mb
    id
    00005258
    boot done
    set baud
    921600
    set baud done
    check flash
    Current eeprom imei354876092154899
    current otp imei
    354876092154899
    file saved
    C:\program files\infinitybox\lga\eeprom_354876092154899_lg-kg130_20101006-123959.b1e.bin
    Version234-30v10a44kg130p40fl
    reading 234
    -30v10a44kg130p40fl_eeprom-ffs_354876092154899
    File saved
    C:\program files\infinitybox\lga\234-30v10a44kg130p40fl_eeprom-ffs_354876092154899_lg-kg130_20101006-124108.b1e.bin
    check flash done
    check space
    Check space done
    check parameters
    Check parameters done
    erase
    Erase done
    write
    Write done
    finished
    time used106 sec
    remove
    /install battery now
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  8. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  9. #5
    Dec 2009
    GIALAI
    flash china 6229 128MB ok by infinity
    PHP Code:
    COM3 [VCP0selected
    module  v3.57
    Device
    :Autodetect 6205-6239 NOR
    Checking data
    wait...
    Actionwrite flash NAND
    write
    Firmware
    00
    -V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin
    skip
    Customization/Language Pack
    skip
    Customization
    skip
    Eeprom/ffs
    nfi area detection
    external bootloader is not present
    bootloader version
    A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin
    nfi area detection
    (3 coresfinishedOk
    interface: BROM_DLL_v3.1016.00
    Connect
    Phone should be Switched OFF !
    Connecting...
    Booting...
    Release Power button now !
    bootcode current/expected3.2/3.2
    CPU
    6229:8A02:8A02
    status
    FF
    bbchip bl ver
    FE
    NOR flash chip
    not installed
    NAND flash id
    [0014]: 0098:00F100900095 [TOSHIBATC58NVG0S3AFT
    chip size
    128Mb
    page
    /spare size0800/0040
    pages per block
    0040
    bits i
    /o08
    address cycles
    04
    internal RAM size
    00020000
    external RAM
    S_DA_RAM_ERROR
    done
    Set baudrate
    (921600)...
    done
    ram test
    testing...
    ram test passed
    ===>  detect existing firmware structure...
    detect ffs...
    detect sec ro...
    detect custom parameters...
    detect project-id...
    detect NAND info...
    number of areas/bytes to read1:00080000
    reading
    (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
    nfi area detection...
    warningheader is empty: probably flash chip completely erased
    warning
    can not detect header
    nfi area detection
    (0 coresfinishedfailed
    warning
    ffs can not be detected
    TCL
    -ID detection...
    TCL-ID detection done
    startup code area
    #1 detection...
    startup code area #1 detection done
    code offset00000000
    ===>  done
    nfi area detection
    bootloader version
    nfi area detection
    (3 coresfinishedOk
    startup code area
    #1 check...
    errordone
    number of cores
    3
    loading files
    number of areas3
    done
    write
    write bootloader...
    write core...
    Disconnect...
    done
    Finished
    time used6 min 31 sec
    Remove
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  10. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  11. #6
    V.I.P UNLOCKDTDD's Avatar
    Feb 2009
    unlock zte _g_s 213 ok
    COM5 [VCP1] selected
    module v3.71
    Action: "sp-unlock"
    unlock method: smart fast
    Model: ZTE-S213
    Checking data, wait...
    19200 autodetect
    Initializing [6223:8A05:8A00]...
    CPU: MT6223
    chip: 0011:67DD:000C
    status: FF
    Connecting at 19200, wait...
    Phone detected, wait...
    Hardware: MT6223,E05
    Date: 2000.00.00
    Version: 1.0
    Version: KE-KP-BE9D-P109A14V1.0.1B02
    Version: ZTENJ23D_09A_HW
    86 byte(s) read
    imei: 86491300878325
    connection Ok
    192 byte(s) read
    reading data...
    reading data #2...
    building new data...
    writing data...
    180 byte(s) read
    reading data...
    972 byte(s) read
    writing data...
    verifying...
    verification Ok
    done
    Finished, time used: 12 sec
    Yahoo :quynhmy93 , dt: 0917143611
    unlock _ nạp tiếng việt _ nâng cấp phần mềm ---> các loại mobile
  12. ( UNLOCKDTDD ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  13. #7
    Feb 2009
    đây là log write flash
    module v3.71
    Device: ZTE-S213
    Action: write flash
    "smart write" active
    write: Firmware
    ZTE-G-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02_2010-11-10_En_Khmer.B0M.bin
    skip: Customization/Language Pack
    skip: Customization
    skip: Eeprom/ffs
    ffs/eeprom backup enabled, it may takes several minutes !
    ====> Boot ...
    19200 fixed
    Connecting, wait...
    CPU: MT6223
    status: FF
    boot packet size: 0400
    Boot Done
    flash: 208848FFFFFFFF:20884800000000
    flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
    otp offset: 007F0000
    Initialize Done
    ====> Set baud ...
    921600
    Set baud Done
    rom info structure: [standard] type (07)
    TCL-ID is absent
    rom info ver: 07
    sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02.BIN
    project-id: KE-KP-BE9D-P109A14V1.0.1B02, 00000000
    ffs offset/size [02]: 006F0000/00110000
    TCL-ID is absent
    ffs/eeprom address assigned: 006F0000
    Check firmware content Done
    ====> Backup required data ...
    reading: ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02__ffs...
    file saved: C:\Program Files\InfinityBox\MModule\ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02__ffs_20110109-075716.B0E.bin
    Backup required data Done
    ====> Patch required data ...
    Patch required data Done
    ====> Special operation ...
    Special operation Done
    ====> Write ...
    Area: Firmware
    Write: Firmware
    usb bootloader (file) is absent
    sec info (fast) detection...
    Write Done
    ====> Finalization ...
    Finalization Done
    Finished, time used: 1 min 47 sec
  14. ( UNLOCKDTDD ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  15. #8
    Dec 2009
    GIALAI
    repair bad softwaze 1110i china ok
    COM22 [VCP0] selected
    module v3.23
    Action: repair "Bad software"
    Step 1 of 2 is complete !
    Press "Ok" now and then make step 2 !
    If phone did not connect: remove/install battery.
    Model: Autodetect 6205-6239 NOR
    19200 autodetect
    Initializing [6223:8A04:8A00]...
    CPU: MT6223
    high speed boot On
    chip: 0011:396B:000C
    status: FF
    Hardware: MT6223,E04
    Date: 2000.00.00
    Version: 1.0
    Version: N1112_V5.53
    Version:
    detecting structure #2...
    0 done
    44 byte(s) read
    imei: 13579024681122
    warning: current phone imei is incorrect !
    It's need to repair imei for correct phone functionality !
    connection Ok
    detecting structure #6 (mode-1)...
    0 done
    181 byte(s) read
    writing data...
    verification...
    verification Ok
    Finished, time used: 41 sec
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  16. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  17. #9
    Dec 2009
    GIALAI
    UNLOCK ZTE X761 ok
    COM4 [VCP1] selected
    module v3.00
    Device: ZTE-X760
    Action: "sp-unlock"
    unlock method: standard
    ====> Boot ...
    19200 fixed
    Connecting, wait...
    Initializing [6225:8A05:8A00]...
    CPU: MT6225
    chip: 0001:6A03:000A
    status: FF
    Boot Done
    flash: 01227E22312200:18E59F00000000
    flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
    Initialize Done
    ====> Set baud ...
    921600
    Set baud Done
    rom info structure: 2nd [enhanced] generation
    TCL-ID is absent
    startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.91053 EE4.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BF FA112.BIN_8D991045].rpl
    device-id: 91053EE4
    rom info ver: 04
    sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BF FA112.BIN
    project-id: X760_Z10UK_GD_BFFA112, 4510998D
    TCL-ID is absent
    ffs/eeprom address assigned: 00E00000
    startup code area #1 check...
    startup code area #1 fixed
    reading: ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_ GD_BFFA112__ffs...
    file saved: C:\Program Files\InfinityBox\MModule\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_ GD_BFFA112__ffs_20100105-143058.B0E.bin
    detection procedure, wait...
    detection procedure completed
    detecting parameters to apply patch area 1...
    error: area 1 can not apply patch
    detecting parameters to apply patch area 2...
    required data found
    Write: area 2 (pass 1)
    area 2 patch applied Ok
    detecting parameters to apply patch area 3...
    error: area 3 can not apply patch
    ====> Write ...
    Write: ffs
    Write Done
    Finalization Done
    file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_ GD_BFFA112__system_log_91053EE4_8D991045_20100105-143255.B0X.bin
    Finished, time used: 3 min 49 sec
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  18. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  19. #10
    Dec 2009
    GIALAI
    UNLOCK KG 195 ok
    COM3 [VCP0] selected
    module v3.00
    Device: LG-KG195
    Action: reset settings ("format ffs")
    ====> Boot ...
    19200 fixed
    Connecting, wait...
    Initializing [6226:8A02:8A01]...
    CPU: MT6226
    chip: 0031:F3C1:BC56
    status: FF
    Boot Done
    flash: 98004900000002:29EA0000000000
    flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
    Initialize Done
    ====> Set baud ...
    921600
    Set baud Done
    interesting cpu type found
    rom info structure: 2nd [standard] generation
    TCL-ID is absent
    rom info ver: 04
    sw version: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1B.BIN
    project-id: 7S7332SA00-001-R1B, 00000000
    TCL-ID is absent
    reading: LG-KG195_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1B__ffs...
    file saved: C:\Program Files\InfinityBox\MModule\LG-KG195_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1B__ffs_20100108-125212.B0E.bin
    ====> Write ...
    Write Done
    ffs formatting...
    Finalization Done
    Finished, time used: 1 min 41 sec
    File system has been modified !
    It is need to press and HOLD phone "Power" button
    during long time (up to 1 min) to make phone Powered-On !
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  20. ( GIALAI_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MT BOX (29-06-2011)
  1. Trả lời: 86
    Bài viết cuối: 24-07-2016, 23:49
  2. Trả lời: 43
    Bài viết cuối: 07-08-2014, 09:15
  3. Trả lời: 91
    Bài viết cuối: 13-08-2013, 17:42
  4. Trả lời: 2
    Bài viết cuối: 27-09-2012, 17:43
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 20:26
