Trang 22 của 26 Đầu tiênĐầu tiên ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 CuốiCuối
Kết quả 211 tới 220 của 255
  1. #211
    Jan 2007
    Infinity Chinese Miracle-2 CM2MT2 v2.35 - general improvements and fixes
    - Internal changes and fixes for protocols applied
    - Internal changes and fixes for flasher applied
    - Internal changes and fixes for preloader parser applied
    - Preloader database handling updated
    - Preloader database remote verification enabled by default
    - Log engine updated: log files created for each session and stored to /log/ directory
    - Deep Info parser enabled by default
    - User Interface updated
    - Product-specific Loader [DA] files moved to CM2MT2-boot-pack
    - Required Dongle firmware version: 0153
    Download link #1
    Download link #2
    Download link #3
    Previous discussion CM2MT2 v2.34 is here
  2. #212
    Jan 2007
    Infinity Chinese Miracle-2 #CM2MT2 v2.36 - general improvements and fixes
    Dongle firmware version required: 0153
    - SmartInfo parser output revised
    - NVRAM parser output revised
    - Firmware remote verification enabled
    - Device remote verification enabled
    - Preloader parser revised and fixed
    - Peloader remote verification enabled
    - "KG State" moved to Service page
    - "Help" menu
    - View log files by right mouse click on message window
    - View log files via "File" menu
    - "Logs" button at main window to view log files
    - "Snap" button at main window to make screenshot
    - "Stop" button at main window
    - Verification for preloader|da|firmware integrity
    - Show current settings at operation start
    - Show "Local SLA" state at operation start
    - Show "Flash Write" settings at operation start
    - "HW Report" mode selection changed
    - "Check Account" button at "Settings" page to verify Username and Password validity
    - Loaders remote verification enabled
    - Show loaders information at boot time
    - Memory chip life-state warnings updated
    - "Stop" item removed from the top menu
    - Boot stage loader files information revised
    - "GUI Mode" item removed from the top menu and moved to "View" button
    - "Memory Tool" moved to "Service" page
    - "Make Service Report" moved to "Service" page
    - "Settings" -> "Firefy : EMI" menu item moved to "FireFly : AutoEMI" at "Settings" page
    - "GUI mode" save/restore on startup
    - "Change GUI mode" via "Settings" menu
    - HW Compatibility Wizard enabled
    - Server Hints engine enabled
    - "PMT Info" option at "Platform" page display Partition Info during "Identify"
    - "Save Boot Config" option at "Platform" page to store detected model config to models list
    Download link #1
    Download link #2
    Download link #3
  3. #213
    Jan 2007
    Infinity Chinese Miracle-2 #CM2MT2 v2.37 - general improvements and fixes
    - "Restore Backup" config mode updated
    - "Restore Backup" allow to select files manually
    - Flash file (Scatter) Open|Select|Clean buttons at "Flash" page
    - Flash file (Scatter) parser updated
    - Flash file (Scatter) selection issue fixes
    - MemoryTool file selection issue fixes
    - MemoryTool gui minor changes
    - "Switch to HS USB" option removed
    - Config storage engine updated
    - Account Check gives balance and subscription date
    - "PMT Info" config value stored
    - "Flash" page minor gui changes
    - Loaders remote verification revised
    - Installer updated to manage previously installed boot-pack
    Download link #1
    Download link #2
    Download link #3
  4. #214
    Jan 2007
    Infinity Chinese Miracle-2 CM2MT2 v2.38 - general improvements and fixes
    !!! WARNING !!!
    Backup files storage structure changed, files and folders will be compressed. Here is backup files structure
    Software will convert files and folders at first run!
    If you have important data - make /backup/ folder copy for emergency case!
    Process may takes time, BE PATIENT!
    - Startup process revised
    - Backup files are packed, zip and 7z formats are supported (7z.dll is required)
    - Backup files default format is 7z
    - Backup|Restore partitions list updated
    - Backup overwrite request for "Identify" only, skip existing backup replacement for other operations
    - Partition size verification during backup
    - File content verification (zeroes) during backup creation
    - File content verification (zeroes) during backup restore
    - Display hw|sw info to log during backup file selection
    - Restore backup images with .bin and .img extensions
    - Legacy settings values removed
    - MemTool work path save|restore
    - MemTool window position save|restore
    - MemTool ui changes
    - Log window style customization
    - HW Report behaviour changed depends on selected Platform
    - Cloud: display hw|sw info about last connected device
    - Cloud: get previously stored backup file
    - Flash chip vendors list updated
    - ufs parser revised
    - emmc parser revised
    - emmc failure detection improved
    - nand parser revised
    - Firmware read/write last selected path save|restore
    - scatter file creation process rebuilded
    - scatter file load process revised
    - META mode connection method revised
    - META mode info and device version output revised
    - META mode memory leak fixed
    - Check free disk space on startup
    - Check free disk space on Flash Read
    - Flash Read file selection method updated
    - Flash Read process termination revised
    - Backup before Reset in META mode
    - Backup before Reset in Flash mode
    - extcsd backup file content verification
    - PMT (partition table) info output slightly changed
    - PMT (partition table) info included to device.txt during backup
    - Store device.txt with hardware and software info to backup
    - Store device.txt with hardware and software info to firmware
    - Store device.txt file as ini
    - Store loaders config to device.txt file
    - Verify backup presence before process
    - Error messages and software hints updated
    - More software hints for [Format] operations
    - More messages in log about process flow
    - [SMART RESET EXTRA] error handling revised to recover after error
    - Create Screenshot [Snap] as .png instead of .bmp (quite compact)
    - Device brand|model detection revised
    - Updates checker rebuilded
    - External update checker disabled
    - External firmware uploader enabled
    - [Stop] process revised
    - Customs Settings -> EMI button extract prevoader from partition image on load
    - MemTool selection mode for 128 Mb and 256 Mb in list
    - MemTool file selection revised
    - MemTool operations revised
    - [Flash] page minor ui changes
    - [Security] page minor ui changes
    - [NVRAM Read] operation revised
    - [NVRAM Write] operation revised
    - NVRAM backup file format changed
    - [Restore Backup] operation allow to select backup file
    - [Restore Backup] has new restore mode [+preloader]
    - Check free disk space before backup
    - settings.ini new value [where] backup=backup\
    - settings.ini new value [where] boot=boot\
    - settings.ini new value [where] tools=..\tools\
    - settings.ini new value [where] firmware=firmware\
    - SC engine revised
    - Files verification config option in [Settings] page
    - Files verification for nvram backup enabled
    - Memory management engine revised
    - [KG] moved to [Misc] section
    - Dialogs texts revised. Message text will be visible in log window on selection
    - Minor log text messages and ui changes
    - Check required dll's on startup
    - ssleay32.dll included to installer to improve compatibility
    - 7z.dll included to installer
    - /tools/iosFileUploader included to installer
    Infinity Telegram Channel
    Infinity Telegram Chat English
    Infinity Telegram Chat Русский, Українська, Белару́ская #1
    Infinity Telegram Chat Русский, Українська, Белару́ская #2
    Infinity Telegram Flash File search
    Infinity Video Manuals
    Infinity Facebook Page
    Infinity Facebook Group
    Infinity Twitter
    Download link #1
    Download link #2
    Download link #3
  5. #215
    Jan 2007
    Infinity #CM2MT2 boot-pack v2.40
    Infinity #CM2MT2 boot-pack v2.40 with updated loaders
    Loaders & structure updated
    [+] Condor
    [+] Dlight
    [+] Xiaomi/Redmi-9c/ linked to base-2112 + preloader file from /Redmi-9/
    [+] Xiaomi/Redmi-9a/ updated with preloader file from /Redmi-9/
    [+] legacy loaders moved to /0_rare/
    [+] /0_base/v17xx/ moved to boot-pack
    [+] /0_base/v18xx/ moved to boot-pack
    [+] /0_base/v19xx/ moved to boot-pack
    [+] /0_base/v20xx/ moved to boot-pack
    CM2MT2 v2.39 and higher should be used with the next loaders:
    [+] Infinix/Infinix-G99-General/
    [+] Infinix/Dimensity-9000/
    [+] Infinix/X676B/
    [+] Tecno/Tecno-G99-General/
    [+] Tecno/Dimensity-9000/
    [+] Tecno/Phantom-X2-X2Pro/
    [+] /0_generic/ loaders for latest MT6781/MT6789/MT6983 are inside sw installer
    Every new boot-pack release has all previous boot-packs included, it means you should only install latest one to get all loaders
    Download HERE
  6. #216
    Jan 2007
    Infinity Chinese Miracle-2 #CM2MT2 v2.40
    General:
    FireFly : Protocol updated
    FireFly : Activated new operations
    1. Firmware Read
    2. Firmware Write
    3. MemoryTool : EXTCSD Read
    4. MemoryTool : EXTCSD Write
    FormatFS:
    Smart Reset updated: New types supported
    Smart Reset updated: Android 13 specific changes
    Firmware reader:
    Firmware Read activated in FireFly mode
    Android 13 support improved [under test]
    Firmware flasher:
    Flasher Engine updated : [LUCI], [RAPH] and [LEGACY] protocols updated
    Firmware Flashing activated in FireFly mode
    Service:
    Identify : Now read active system info if device belong to AB
    BootLoader: Unlock/Lock revised in FireFly and MTK mode
    MemoryTool:
    New Operation : EXTCSD read - Allow read EXTCSD config from eMMC. Made default at boot also
    New Operation : EXTCSD write - Allow write EXTCSD config in eMMC
    Both operations supported only in FireFly mode for now!
    The Rest:
    Loaders updated
    Previous versions of loaders partially moved to CM2MT2 boot-pack
    CM2MT2 boot-pack v2.40 or newer should be installed to get latest loaders
    Log output management updated
    BugFixes and minor updates
    Required Dongle firmware version: 0154
    Download link #1
    Download link #2
    Download link #3
  7. #217
    Jan 2007
    Infinity Chinese Miracle-2 #CM2MT2 v2.41
    General:
    - FireFly core loader updated: /XFireFly/base/FireFly_AllInOne_DA.bin
    - FireFly mode operations updated such as bootloader unlock etc.
    - Many internal changes
    Image management:
    - Preloader parser/converter updated
    - Preloader/EMI open dialog updated for bin/img files
    - DA, Cert, Auth, Preloader load/verification method updated
    User Interface:
    - log management engine updated
    - software messages revised
    Dongle firmware version required: 0154
    Download link #1
    Download link #2
    Download link #3
  8. #218
    Jan 2007
    Infinity Chinese Miracle-2 #CM2MT2 v2.42
    General:
    - Maintenance release
    - Memory management improved
    - Boot time flow process updated
    - Boot time error handling improved
    User Interface:
    - flash chip info output revised
    - software messages & hints updated
    General:
    Image management:
    User Interface:
    Download link #1
    Download link #2
    Download link #3
  9. #219
    Jan 2007
    Infinity Android Service Tool #AST v1.04
    - Connection methods updated for ADB and Fastboot
    - Latest dll's included in package
    - Stop/Logs/Snap buttons
    - gui updated
    - user interface save/restore options
    - aplication list save on Identify
    - Device messages output method revised
    - Hints and error messages updated
    - "Uninstall Apps" for batch processing by apk list loaded from text file
    - "Pixel" bypass method
    Download link #1
    Download link #2
    Download link #3
  10. #220
    Jan 2007
    Infinity Chinese Miracle-2 #CM2MT2 v2.43
    General:
    - Device/Firmware detection method updated
    - Boot process flow slightly changed
    - Boot/Shutdown process updated
    - Partition table analyzer rebuilded (primary/secondary)
    - Service operations updated - red/orange state and bootloader unlock
    - Bootloader lock/unlock process flow updated
    - Service Report revised
    - FileSystem type output revised
    - Device handling Strategy type output revised
    - scat load & emi management for "flash write" revised
    - MemoryTool operations revised and bugs with menu selection fixed
    - Security values processing updated
    - META mode output revised
    - EMI handling for legacy devices fixed
    - Internal changes - memory management and more
    User Interface:
    - FLASH/META mode selection changed
    - DA Protocol selection changed
    - Software messages & hints updated
    Download link #1
    Download link #2
    Download link #3
Hiện có 5 người đang xem bài này . Bao gồm : 0 thành viên và 5 khách
  1. Z3X BOX LG New Update
    By TuấnPhát_GSM in forum Z3X-BOX FOR LG
    Trả lời: 133
    Bài viết cuối: 19-03-2021, 09:27
  2. NS Pro Update Post here
    By DNA in forum NS Dongle
    Trả lời: 72
    Bài viết cuối: 10-09-2016, 01:13
  3. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  4. CPF Box II New Update AE Post ở đây
    By TuấnPhát_GSM in forum CPF-BOX Ⅱ
    Bài viết cuối: 06-08-2011, 15:31
  5. Trả lời: 0
    Bài viết cuối: 27-12-2010, 21:51
