Trang 23 của 26 Đầu tiênĐầu tiên ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 CuốiCuối
Kết quả 221 tới 230 của 255
  1. #221
    Jan 2007
    Infinity #CM2MT2 v2.44 Infinix/Tecno no need TP and more features
    General:
    - Device info detection revised
    - EMI processing for legacy hardware (f.e. MT6580) revised
    - EMI database rebuilded
    - Meizu operations revised
    - New feature: Brom ON/OFF - allow enable BROM mode and allow do extended services such as:
    All FireFly Features: Boot unlock, testing, service etc.
    All FireFly DA features: Boot unlock, RPMB, service and other
    NOTE: Read BROM On|Off manual
    - Display partition/image size during flash Read/Write
    - Device information parser updated
    - DA selection mode revised
    - DA information/hints displayed on selection for number of loaders
    - DA config database updated
    - Red|Orange state methods revised
    - Incompatible image confirmation during Flash fixed
    - Simlock methods output updated
    - Format methods output updated
    - Infinix and Tecno without testpoint/disassembly included MT6739, MT6761, MT6763, MT6765, MT6768, MT6781, MT6785, MT6833, MT6877, MT6893
    - Internal changes - memory management and more
    MemoryTool:
    - Bulk Read/Write operations updated: selection and Read/Write path sync
    - Read/Write file path handling method on file select/cancel revised
    - Messages & errors|hints updated
    Backup:
    - Backup restore process updated with any record On|Off selection
    - Select All/None items by right mouse click
    User Interface:
    - Startup window position config revised
    - Software messages & hints updated
    Dongle firmware version required: 0155
    Download link #1
    Download link #2
    Download link #3
  2. #222
    Jan 2007
    Infinity #CM2MT2 v2.45
    - startup process and external dll's handling method revised to avoid 0x0c000007b issue with damaged libusb installation
    - boot process revised
    - boot/sla error handling method changed
    - flash read process revised: luci handling updated and more detailed output
    - EMI database structure updated
    - MemoryTool file path handling updated, non-existent path check
    - external dll's moved to /lib/
    - external dll's verification method updated
    - separate fscard.ini file is not required any more
    - strategy detector updated: honor
    - "Restore backup" process revised, issue with filelist fixed
    - flash writer display source file size instead of partition size
    - flash reader: [Create SCAT] option
    - gui resize bug fixed
    - auto-update check method changed to once per day
    - messages and hints updated
    - minor ui changes
    - many internal changes and improvements
    NOTE: install latest CM2MT2 boot-pack for best results
    Download link #1
    Download link #2
    Download link #3
  3. #223
    Jan 2007
    Infinity #CM2MT2 v2.46
    LUCI Devices:
    - MT6983 support fixed
    - UltraFlash protocol updated
    Firmware Reader:
    - Automatic detection activated
    - Software now allow correctly read most modern devices even if they are not tested
    - Avoid possible problems with OTA, damaging vendor-unique stuff or any other identification data
    Firmware Analyzer:
    - Strategy detection revised
    - Firmware version detection methods updated
    Bootloader unlock:
    - Oppo/Realme specific changes
    Factory Reset:
    - Complete rebuild to automatic / vendor strategy depend mode
    Boot methods:
    - boot/DA database management revised
    SCAT loader:
    - Display firmware info on file load
    - Display firmware info on flash write start
    - Verify loaded image via server
    Other changes:
    - minor ui changes
    Download link #1
    Download link #2
    Download link #3
  4. #224
    Jan 2007
    Infinity #CM2MT2 v2.47 - FireFly over preloader mode and more
    Main:
    FireFly DA activated for RAPHAEL devices in preloader mode.
    Support wide range of generic and secure devices on most of the following chipsets:
    MT6755, MT6761, MT6763, MT6765, MT6768, MT6771, MT6779, MT6785, MT6833, MT6853, MT6873, MT6893
    - For secure devices in preloader mode you must use appropriate vendor DA.
    - MT2 package contain range of secure PRELOADER DA for vendor f.e. Tecno, Infinix, Vivo
    It helps to service device over PRELOADER mode without Test-Point
    - You can use own private Preloader DA with any vendor restrictions freely
    Now over preloader with default range of service features you also got Bootloader unlock, RPMB, MemoryTool and other extended service stuff.
    Solution tested and support on wide range of DA from 2017 up to 2023.
    MT6755, MT6761, MT6765, MT6763, MT6771, MT6779, MT6768, MT6885, MT6853, MT6785, MT6873, MT6833, MT6893
    Vivo: Y33s, Y30g, Y51, Y53s, Y19, Y5s, V17-Neo, S1-P65, Y7s, Y21a|V2149, V15|1819, S1|1907N, Y15s|V2120 and more.
    - LUCI protocol updated
    - RAPHAEL protocol updated
    - META/SVE mode protocol management updated
    Boot process:
    - process flow updated
    - process messages and error handling updated
    - connection rebuild in BROM/PRELOADER mode
    Service:
    - Backup restore fixed in "restore all" mode
    - Firmware Reader updated
    - Bootloader unlock process updated (Xiaomi)
    Flash Engine:
    Other changes:
    - server protocols revised
    - hardware compatibility engine updated
    - software messages and hints updated
    - minor ui changes
    Dongle firmware version required: 0156
    Manual https://forum.infinity-box.com/viewtopic.php?t=27162
    Download link #1
    Download link #2
    Download link #3
  5. #225
    Jan 2007
    Infinity #CM2MT2 v2.48
    Main:
    - Vivo without test-point improved and support more flash chip types
    - Boot process slightly updated
    - [MDM Fix] option for security plugins, payjoy etc.
    - [Orange State] operation revised
    - Flash write config options updated
    - Flash write process algo revised
    - SCAT loader revised
    Other changes:
    - minor ui changes
    Download link #1
    Download link #2
    Download link #3
  6. #226
    Jan 2007
    Infinity #CM2MT2 v2.49 - MDM Fix process updated and more
    - [MDM Fix] file creation process rebuilded, more image types supported
    - [MDM Fix] fast direct one click process released. Number of supported devices may be limited for now
    Write your [MDM Fix] result HERE
    - Xiaomi operations revised
    - Server hints/loaders downloading method updated
    - Firmware info extraction on [Identify] method updated
    - Information about written images furing flash changed
    - Retrieve MDM state on [Identify]
    - Retrieve network options on [Identify]
    - eMMC crc verification on boot
    - Loaders updated
    - Many internal changes and optimization applied
    Before run #CM2MT2 v2.49 please fix your PC. Disable/Close TeamViewer, Anydesk, Ultraviewer, Ammyy Admin
    And stop Services:
    1. Right click on This PC => Manage => Services and Applications => Services => Double click to service
    2. Click to [ Stop ] button
    3. Select Manual and click to [ OK ]
    Download link #1
    Download link #2
    Download link #3
  7. #227
    Jan 2007
    Infinity #CM2MT2 v2.51
    NOTE 1: Many new methods are being applied to the latest models. Consider to install this version to new directory and in case of any issue with old models use previously released software version for it.
    NOTE 2: #CM2MT2 v2.51r1 has fixed gui issue with security values selection
    CPU/Platforms:
    LUCI: Protocol updated
    LUCI: Vendor-specific changes
    LUCI: RAMless support activated - RAMless DA must be used, automatic detection
    LUCI: New SOC: MT6835 support activated
    LUCI: New SOC: MT6985 support activated
    More brands are covered in this update: Realme, Oppo, Tecno, Infinix, Lenovo, Moto
    General changes:
    - New loaders and boot method for Tecno/Infinix (without test point)
    - New loaders and boot method for Vivo [luci] (without test point)
    - New loaders and boot method for Realme [luci] (without test point)
    - New loaders and boot method for Oppo [luci] (without test point)
    - New loaders generic models base_v2316
    - Loaders config for xioami updated
    - Loaders storage tree updated to make easier selection
    - Boot procedure updated
    - Legacy devices (MT6580 and similar) connection process revised
    - Supported CPU list updated: MT6835, MT6985
    - MemoryTool filesystem detection method updated
    - MemoryTool|RawTool updated
    - MemoryTool messages updated
    - MDM operations updated
    - Device info parser updated
    - Firmware analyzer updated
    - EMMC hardware fault detection improved
    - Server firmware verification method updated
    - Startup Logs Analyzer added to [HW|SW reports]
    - Format/Reset mode selection method changed, all operations rebuilded
    - [Probe rpmb] option for [Identify]
    - Filesystem(s) detection method updated
    - gui changes
    Download link #1 Download link #2
  8. #228
    Jan 2007
    Infinity #CM2MT2 v2.52
    - Boot procedure updated (BROM mode)
    - More loaders included in package
    - [Smart] Reset method updated
    - vivo sec processing updated
    - oppo regionlock via [Smart] Reset
    - Display FRP status during [Identify]
    - Firmware version detection method updated
    - MemTool path selection method updated
    - Reset FRP and Bootloader state options during flash write
    - Needless firmware version check during flash write removed
    - Legacy config parameters removed from [Settings]
    - Database location changed to /cfg/ directory
    - Minor gui changes
  9. #229
    Jan 2007
    Infinity CM2SP3 v2.20r1 released, more SoC and 400+ new devices supported
    Completely rebuilded CM2SP3 tool released with unique servicing methods and functions.
    For now 400+ devices and number of SoC in list, unique hardware fault detection methods and special FireFly [FF] boot mode.
    More features comes step-by-step
    [A] acer, agm, alcatel, alldocube, archos
    [B} benco, blackview, blu, bimax, bq
    [C] chuwi, coolpad, cubot
    [D] dexp, digma, doogee, doro
    [F] foxdd, freeyond
    [G] general-mobile, gionee
    [H] headwolf, hiper, hisence, honor, hotwav, htc
    [I] IIIF150, infinix, inoi, itel
    [J] jumper
    [K] kenxinda
    [L] lava, lenovo, letv, lg
    [M] meizu, micromax, motorola, myphone
    [N] n-one
    [O] oppo, oukitel
    [P] panasonic, philips, phonemax, prestigio
    [R] realme
    [S] samsung, signma-mobile, sunwind
    [T] tcl, teclast, tecno, topdevice, tp-link-neffos
    [U] ulefone, umidigi, uniwa
    [V] vastking
    [W] wiko
    [X] xgody, xiaolajiao, xiaomi
    [Z] zte
    SoC: T310, T606, T609, T612, T618, sc9230, sc9820, sc9832, sc9863
    - [LiveBoot mode] activated: boot once, do what you want
    - Standard FDL and custom FireFly [FF] loaders are supported
    - External FDL1/FDL2 loaders support
    - External PAC file as loader support
    - Server authentication for number of operations available
    - EXTCSD EMMC info extractor
    - EMMC chip health status report to detect faulty EMMC
    - HW|SW Report: extract startup logs/faults
    - Device hardware and software info read on [Identify]
    - Sensitive data [Device-ID] backup create on [Identify]
    - Sensitive data [Device-ID] backup restore (own or with selection)
    - [Device-ID] read/write [diag]
    - [Device-ID] read [boot]
    - WiFi MAC address read
    - WiFi MAC address fix
    - Bluetooth MAC address read
    - Bluetooth MAC address fix
    - [Disconnect] button to release device connection
    - Reset frp
    - Reset filesystem: userdata
    - Reset filesystem: wipe
    - [Smart] reset to fix ota and nvram issues
    - PAC file information extractor
    - Sound alert on critical errors during read/write
    - Account status check
    - Updates checker
    - Progress display percent with decimal separator to be more precise
    - Separate operation log file in /log/ directory for each session
    - [Snap] button for instans software screenshot
  10. #230
    Jan 2007
    Infinity #CM2SP3 v2.26 released
    - Many new models in list
    - SC7731e [FF] protocol released for advanced service options
    - [RPMB Write] function in addition to previously released [RPMB Read]
    - RPMB Smart Write enabled to optimize and make faster RPMB write process
    - Filesystem parser (ext4) revised
    - RPMB autobackup on Connect
    - [Change Active Slot] option for [MemTool]
    - [Device-ID] functions revised
    - GPT parser revised
    [AppTool] feature via [FF] mode
    - Print list of available/installed APK
    - Disable any (even system) APK pernamemntly
    - Disabled APK stay disabled even after Reset or Wipe
    - Save list of installed APK to file
    - Restore disabled APK back anytime
    - Extremely fast processing
    NOTE: Bootloader must be unlocked for this operation
    What [AppTool] can do:
    - OTA On/Off
    - MDM/Admin Apps On/Off
    - Bloatware/Telemetry/Spy Apps On/Off
    - Network/Operator addons On/Off
    - And many more features depends on your fantasy
    - Devices list updated with more models
    - Built-in boot pack files updated
    - Config options save/restore on startup
    - Minor gui changes
    - Internal improvements and fixes
    HOW TO USE
  1. Z3X BOX LG New Update
    By TuấnPhát_GSM in forum Z3X-BOX FOR LG
    Trả lời: 133
    Bài viết cuối: 19-03-2021, 09:27
  2. NS Pro Update Post here
    By DNA in forum NS Dongle
    Trả lời: 72
    Bài viết cuối: 10-09-2016, 01:13
  3. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  4. CPF Box II New Update AE Post ở đây
    By TuấnPhát_GSM in forum CPF-BOX Ⅱ
    Bài viết cuối: 06-08-2011, 15:31
  5. Trả lời: 0
    Bài viết cuối: 27-12-2010, 21:51
