Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10il
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10il
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mr
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84D74DA7FAAC29B7A8377C350B
MSID decoded: 3E4EBAE90052D035A8000000
FAID: D1937D9F98A1739EFCDE7A20
Operation took 0 minutes 15 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 2 seconds...
Writing...
Permanent Data Restore FAILED!
Operation took 11 minutes 56 seconds...
Restarting MCU...
Failed! Aborting!
Máy ban đầu tình trạng trắng màn, đã làm lại CPU & Flash đặc biệt là khi chạy phần mềm rất chậm?
