Kết quả 11 tới 14 của 14
    Thành viên chính thức tienkdt's Avatar
    Bắc Giang
    Mặc định Jaf flash 7610 báo này là sao à
    Mình chạy con Nokia 7610 báo này là sao nhỉ
    Code:
    Getting MCU ID
    MCU ID: 0x1081
    FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 7.0642.0
    18-10-06
    RH-51
    (c)NMP
    HW version: 7029
    PCI version:
    UEM version: 144
    UPP version: 4225
    RFIC version: 0205
    DSP version: CN5.10
    PPM version: V 7.0642.0
    18-10-06
    RH-51
    (c)NMP.33
    Production serial number: SEI501297
    Product code: 0516453
    Module code: 0202215
    Basic production code: 0528496
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: s?????????????????????????????????????????????????
    Default SN type: s?????????????????????????????????????????????????]
    IMEI plain: 357070004993517
    IMEI spare to net: 3A 75 70 00 40 99 53 01
    IMEI SV to net: 33 75 70 00 40 99 53 31 F3
    PDC: 4E 54 54 4A 50 12 34 56
    Master Code: 3204212455
    Phone type: RH-51, Software version: 7.0642.0, Language Pack: 33
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
    Setting local mode...
    Reading product code...
    Product Code: 0516453
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
    Scanning for ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.33
    Languages in ppm: English,Bahasa Mal.,Bahasa Ind. (Apac-3)
    Done!
    Changing flashing settings...
    Reading...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.67
    Languages in ppm: English,Finland CV
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\357070004993517_imei_backup_2328179.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1
    Booting phone...
    MCU ID: 0x1081
    BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
    Boot size is 0x10D8
    Boot is ready...
    Flash ID is 0xDDFE00EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
    Loader size is 0x7F10; Loader chk: 4
    Loader is ready...
    MSID: 844BE6AC1E960A07B799FC781F
    MSID decoded: 3E4EBAF700839AE9A9000000
    FAID: 780411F4DC724AA1562ED2FA
    Operation took 0 minutes 18 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00FFFFFF...
    Erasing area: 02000000 - 0287FFFF...
    Erasing area: 02FC0000 - 02FEFFFF...
    Operation took 2 minutes 43 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 3 minutes 31 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.67
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x10D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 02A00000 - 02CAFFFF...
    Operation took 0 minutes 19 seconds...
    Writing...
    Operation took 0 minutes 22 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 7 minutes 38 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Failed! Aborting!...MCUVER
    Reading...
    Failed! Aborting! MCUVER
    Cứ đến đây là lỗi
    Reading...
    Reading...
    Anh em ai biết chỉ cái
    AZ mobile http://a-zmobile.net.=> sẻ chia kiến thức ~ nâng tầm công nghệ
  1. Flash 7610 báo lỗi !
    By tanphongforum in forum DCT4 - WD2
    Bài viết cuối: 07-09-2009, 14:45
  2. flash 7610 xin chỉ giúp các anh em ơi?
    By BENTRE GSM™ in forum NOKIA
    Bài viết cuối: 14-10-2006, 18:10
